20 Most Recent GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Questions & Answers
How to change the water filter on a galaxy 25.4 cu. ft. side-by-side refridgerator
Check the "grill". Best Buy's ad spec sheet stated the filter was located in the grill. I believe there's an access panel on the bottom front of the grill below the doors.
7/28/2014 10:15:03 PM • GALAXY... • Answered on Jul 28, 2014
Where is the water filter on galaxy model
at the bottom below door
6/28/2014 4:44:28 AM • GALAXY... • Answered on Jun 28, 2014
0answers
Water is filling up in bottom of freezer
Hi, in the freezer there is a drain hole, this hole is obstructed, clear this drain system with hot water or air pressure and this should solve this issue. Good Luck I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
12/24/2013 1:34:50 PM • GALAXY... • Answered on Dec 24, 2013
Fan noise coming from inside a kenmore elite refrigerator..
Sounds like the fan gas come loose on the shaft and slid into its cage.
12/15/2013 3:43:16 AM • GALAXY... • Answered on Dec 15, 2013
WATER DISPENSER ON GALAXY SIDE BY SIDE REFRIGERATOR DOESN'T WORK
Sounds like if your ice maker is still working, you're having an issue with your filter maybe freezing. Check to make sure your water filter isn't froze. What you're talking about with the overflow is a coincidence, but unless the internal wiring for the unit inside of the dispenser got damaged, i doubt thats the reason why. It's either a frozen filter or bad water valve. Try dethawing the filter or taking it out and seeing how much pressure there is built up in it. There's also a water reservoir in the back of this unit that may be froze too.
11/28/2013 3:41:11 PM • GALAXY... • Answered on Nov 28, 2013
I have a Galaxy 25 cu. ft side by side with ice
it appears as though you have replaced everything in the defrost circuit.. there is no mechanical timer, the defrost control is the circuit board up by the other 2 thermostats/cold controls, damper control box..
either theres a bad connection somewhere (could be a bad moly plug connection) or just a defective component you replaced..
the defrost thermostat should only have continuity when its frozen, once it warms it should open signaling the defrost control that the cycle is complete and to once again begin cooling..
hope this helps,
best of luck,
ttfn
10/22/2013 11:46:16 AM • GALAXY... • Answered on Oct 22, 2013
Mold growing around ice dispenser area. Cant
Pull ice maker out and clean it. Then make sure you have a fresh water filter on water supply. Mold in the freezer is uncommon if its truly freezing inside. You have dirty water coming in. If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
10/13/2013 8:15:26 PM • GALAXY... • Answered on Oct 13, 2013
0answers
Model 106.55122700
Be the first to answer 8/12/2013 5:32:10 AM • GALAXY... • Posted on Aug 12, 2013Be the first to answer
GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
Popular Tags
148 questions posted
Top GALAXY Microsystems Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • GALAXY Microsystems Refrigerators
Most Popular Question
maytag ice maker floods kitchen when
  • Refrigerators
