I've been using the wireless from my router just fine for months but suddenly it's not working. It's nothing to do with my laptop's ability to connect to wifi, though, as I'm able to connect elsewhere. I went to the IP address page, logged in, and sure enough it says the wireless connection is disabled but won't let me click it to enable it. What should I do?
SOURCE: Wi-Fi isn't working
This could be a duplex issue. When you log into the belkin does is assign you an IP address? Have you used a ballpoint pen to reset the EMTA since you have connected the router?
SOURCE: Trying to get my ps3 connected so i can get online
You need to disable the UPnP function on the Belkin router. Log into the router(192.168.2.1), and look under System Settings. If you haven't changed the password on the router, the default password is blank, i.e., no password.
SOURCE: i want 2 play my ps3 online using my arris modem
You should use a router, but if you cant, try hooking everything up like normal, then pull the power cord on modem for 10 full seconds, hook back up, wait 5 minutes and then try.
SOURCE: My belkin54g router is currently hooked up to the
Change the router! or go to Belkin : Support : Setup Assistant for Routers
SOURCE: We have had a Motorola Surfboard SGB6580 for a
how can I shut the firewall off so other people in my house can acess the net
Change Your Wireless Channel
If you're using a Linksys router, you'll need to browse to the address of your router, which is probably set to http://192.168.1.1 but could be assigned to another address. You can run a quick ipconfig command at the command prompt to check:
In my case the address is different (because I changed it, of course), but what you're looking for is the Default Gateway for your Wireless connection, and then go to http:// in your browser. Enter in the password that you hopefully remember, and head to the Wireless -> Basic Wireless Settings tab.
My router has two separate bands, but your router might just have a single band here. In my case, what I've done is set the 2.4 GHz band to only be used for Wireless-G, and the 5GHz one to Wireless-N only. Since I'm not having any problems with the Wireless-N settings, I've left those on auto.
Where I am having a problem, however, is my Wireless-G devices-so what I've done is chosen channel 9, since it's the only channel that's not being used by any of my neighbors, who are using mostly channels 1 and 6, though a few are using 11 as well.
Channels 1, 6, and 11 are the most common channels to choose, and most routers will use one of them as the default channel-but the general idea is to be as far away from everybody else as you can.
Note: I've also configured my router for 20 MHz only on the 2.4 GHz Wireless-G band, just because that was the only way it would let me choose the standard channel manually.
If you are using a different router, the IP address will generally be the same, but you'll have to figure out how to change the Wireless channel without any screenshot tours. It's usually fairly easy, though, once you know what you're looking for.
Fun Technical notes
