1. Make sure that your PC is connected to your router and the router is powered on.
2. Insert the Resource CD that came with your router into your PC. The CD automatically starts and detects the language you are using on your PC. Select a different language option, if you prefer. If the CD does not automatically start, browse the CD and double-click on .
3. Click Supporting Software, then Netgear Firmware Recovery Utility, and follow the prompts for the recovery process.
4. After firmware recovery is complete, follow the prompts to restore your configuration
You can only use it in the 2.4 ghz mode or the 5 ghz mode:
1. Log in to the Router by going to http://www.routerlogin.net or http://www.routerlogin.com
and entering the default user name admin and default password password, or using whatever
LAN address and password you have set up.
2. Select Wireless Settings under Setup in the main menu to display the Wireless Settings
screen.
3. Select the region in which the wireless interface will operate.
4. Set up the 2.4 GHz wireless network:
a. Enter the SSID name. The default is NETGEAR.
b. Select the operating channel for the wireless mode. The default is Auto. When Auto is
selected, the router finds the best operating channel available.
If you notice interference from nearby devices, you can select a different channel.
Channels 1, 6, and 11 will not interfere with each other.
c. Leave the wireless mode set to the default setting of Up to 145Mbps for 2.4GHz.
5. Select security options for the 2.4GHz wireless network.
The wireless Security Options are set to None by default. NETGEAR strongly recommends
that you use wireless security. You can select a different Security Option and a different
passphrase for each wireless network. For the highest performance of the 2.4GHz wireless
network and the most secure encryption, NETGEAR recommends that you use WPA2-PSK as
your security option.
6. Set up the 5GHz wireless network:
a. Enter the SSID name. The default is NETGEAR-5G.
b. Select the operating channel for the wireless mode. The default channel is 36. If there is an
Auto option in the channel list and you select it, the router will find the best operating
channel available.
c. Leave the wireless mode set to the default setting of Up to 300Mbps for 5GHz.
7. Select security options for the 5 GHz wireless network.
passphrase for each wireless network. For the highest performance of the 5 GHz wireless
network and the most secure encryption, NETGEAR recommends that you use WPA2-PSK asyour security option.
8. Click Apply to save your changes.
please rate it and give a testimonial for my response
Thanks, Joe I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
235 questions posted
1,980 Questions
758 Questions
457 Questions
324 Questions
292 Questions
