20 Most Recent
NetGear DGN1000 Wireless Router Questions & Answers
Runtime error
Look at the back of the router it gives all the default information to use on a web browser (to avoid the runtime error)
Press the Restore Factory Settings button, on the bottom of the unit, for 6 seconds.
Connect via a Ethernet cable and put in the gateway address of
192.1.168.1 to the web browser to see the login screen.
User name is admin, password is password.
Then you can reconfigure the router to your set-up.
Here is the manual.
http://www.downloads.netgear.com/files/GDC/DGN1000/DGN1000_UM_29Feb12.pdf
Lost my Wireless name (SSID)
lost my Security
1. Open your internet browser.
2. Type in 192.168.0.1 and press enter.
3. When prompted, type in admin for username and password for password. That should get you into all of the settings, where you can view your wireless network's SSID and security passphrase.
4. CHANGE your username and password. This is how hackers access your network!
Cant access router
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -http://192.168.0.1The default login = adminThe default PW = passwordYou can now change the default admin password and configurethe wireless settings.Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.Apply these settings to the wireless card in your laptop/computer.To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
How do i change password
to change the password on a netgear, you first need to secure or make sure that you are connected to it. be it wireless or hardwired. after ensuring that your laptop is connected, open a browser, and type 192.168.1.1 or www.routerlogin.net, then it would ask you for a username and password. username is " admin " password is " password " then it would take you now to the netgear page. on the left side of that screen, click on wireless settings, then you can start changing your password in security option. then click apply.
Wierless router not responding
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
How to change the channel on my router?
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under wireless there is channel option8. the best channels to use are 6 and 11 then save it
I have a problem with my router login.I have tried
If the router ssid reads virginmedia.... then you have not reset the router. The default name for a Netgear router is Netgear.Push the reset button in (on the back of the router) and hold it for at least 15 seconds or until the power light flashes.Now the username and password and SSID should be reset to the default.
Ive currently got the netgear
Check the following and then try the solution:
1. Do you have other wireless devices connected?
Yes, go to solution #1, if you know the SSID then try solution #2
No, go to step 2.
2. Are there any wifi connection listed in range?
No, go to step 3
3. Go to a location were you know there is a wifi connection, can you see this connection in the wireless assistant?
No, go to solution #2
#1 my thought is you are not sure of what the SSID is, so place the laptop next to the Netgear router and chose the best wifi signal to connect to in wireless assistant.
#2 There is a switch/or button on the laptop to turn on the wireless. It is normally somewere on the side of the laptop, turn it on and it should glow blue. Now try to connect to your router.
Hope this helps
