20 Most Recent Gateway NV55C03u Laptop Questions & Answers
Your VGA connector has a broken solder joint on the video board or the mother board. This isn't an easy fix.
Suggest you look for a VGA to USB dongle or adapter instead. Install the driver, and you should be good to go. You'll just have to take your dongle along whenever you need a VGA connection.
Gateway NV55C03u... | Answered on May 14, 2017
Does your WiFi work on the laptop work in another place... Starbucks for example? If so, then there is a software security issue with the router, you will need to call the ISP for adjust the settings. If you PC doesn't work with wifi at Starbucks then you have a software issue with your laptop. Go to MY Computer, Hardware/Devices and look for any yellow marks. There will probably be one where the wifi is located. (Expand all the devices by clicking on the plus "+ signs. Find the wifi modem, there are many mfrs; Broadcom and Atheros are two ones. Go into the submenus and driver update too and write everything down you find. The most important things are the description, model number, software version and version date. Navigate to the hardware mfrs site and download and install the newest drivers for the wifi modem. Re-boot and try again to establish a connection.
Gateway NV55C03u... | Answered on Apr 29, 2015
Re-install the application.
Gateway NV55C03u... | Answered on Mar 15, 2015
Take the battery out of the laptop and then hold the power button on the laptop for 2 minutes.
This should reset the BOIS and erase the unlock password.
Gateway NV55C03u... | Answered on Dec 06, 2014
SATA WDC WD5000BPVT-22HXZ master password NEEDED
Gateway NV55C03u... | Answered on Dec 13, 2013
desconect from power, remove main batery and also need open with screw driver in orther to remove bios batery too, wait for around 5 minutes and u done. this works for me on a gateway model NV55C hope this help
Gateway NV55C03u... | Answered on Jun 11, 2013
Just put it to sleep.
Gateway NV55C03u... | Answered on Feb 16, 2013
Have you tried downloading the network drivers appropriate for your computer from the manufacturing website? Of course downloading them via another computer witch has connection to the internet?
Gateway NV55C03u... | Answered on Nov 23, 2012
TRY password 76585858 works on my laptop when in says Primary Master WDC WD3200BPUT-22ZES Lock keep this code safe as i have to keep retyping each time i turn on the laptop, Emily.
Gateway NV55C03u... | Answered on Feb 10, 2012
There's a company called Le River House selling one on eBay for $35 plus shipping. Here's the link to the sellers page. I couldn't immediately find one from an independent company but if you get stuck you could always order replacement parts direct from Gateway by clicking on this link.
Gateway NV55C03u... | Answered on Apr 14, 2011
just check that u have the drives installed for ethernet controller
if u r having though u getting same problem just do uninstall the lan adopter drivers and install again u can get solve ur problem
vote me
Gateway NV55C03u... | Answered on Mar 28, 2011
That is normal. It does that because a temperature sensor controls the uProcessors temperature and tries to keep it less than 50 degrees C. When it gets less than that the fan switches off.
Hope that explains it for you.
Gateway NV55C03u... | Answered on Feb 28, 2011
Dear User,
I would request you to please elaborate the issue if you are facing in your laptop so I can assist you accordingly.
Regards,
Tech_Comp
Gateway NV55C03u... | Answered on Feb 22, 2011
It is better to use your browser to clean-up temp internet files.
For Internet Explorer do the following...
1. while in Internet Explorer
2. click on Tools in either the Menu or Command bar
3. click on Internet Options at the bottom of the pop-up menu
4. on the Browsing history part of the Internet Options window
5. click on the Delete... button
6. on the resulting Delete Browsing History window
7. check-mark Preserve Favorites website data
8. check-mark Temporary Internet files
9. make sure everything else is not check-marked
10. click the Delete button at the bottom of the window
If you want to delete other items, check-mark them prior to pressing Delete button.
If you want to manage Temporary Internet Files click on the Settings button
and set appropriate options in the Temporary Internet Files and History Settings window.
Finally, click OK when exiting to save the changes otherwise click the Cancel button.
Gateway NV55C03u... | Answered on Feb 12, 2011
Press the fn key and the f6 key at the same time and see if that works.
Gateway NV55C03u... | Answered on Feb 10, 2011
does the fan run normally when doing other things?
Does the fan make any unusual noises?
Is it dirty, or coated with dust?
Sometimes cleaning and oiling will keep you working for some time.
Gateway NV55C03u... | Answered on Dec 26, 2010
Gateway NV55C03u Laptop Logo
29 questions posted
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
nv Gateway
  • nv Gateway
Most Popular Question
sata port o wdc wd3200bpvt 22zeslock
  • Computers & Internet
