Each time I try to 'text' a name to send a song to by tagging them NOTHING HAPPENS--their names should 'appear' after I type in a few letters of their names-EG> ' Franc....' -Her name should auto pop up an Then I just 'clik' on the name an IT appears on my timeline!! I need this fixed ASAP!! TY Kindly!! Carole McCarthy> [email protected]
SOURCE: Leapster screen
Sounds like it needs to calibrated - see http://gobaco.wordpress.com/2006/10/31/how-to-calibrate-the-leapster-handheld/
for info,
SOURCE: My auto start will not work
Check the properties for the drive make sure autoplay is enabled.
SOURCE: windows explorer has stopped working
Well if it continues to crash then theres a bigger problem
but a way to make it recover if the EXPLORER.EXE crashes is to hit
CTRL+ALT+Del
File
New task
Then type Explorer.exe and it should reload itsself and be back to normal
i also suggest running a scan with Ad Aware 2008 just in case wat u downloaded could by spyware
SOURCE: Typing delay
I would suspect that you maybe have spyware and malware issue's. you need to get that process list down to an average of 35-40.
spybot is an excellent application to help in a situation like this. Search for it on google.
SOURCE: Medion wireless keyboard MD85750 stopped work.
reinstall key bord drivers first uninstall old drivers then install again
Verify that Bluetooth is turned on or enabled in both your devices. Most cell phones will have a Bluetooth menu in their Settings or Tools. For computers, you may see a Bluetooth icon in your system tray. If unsure, check your product manual for specific instructions.
Follow the instructions to pair (connect) your two devices. If you are asked for a passkey, try entering 0000 which is usually the default for any device.
When prompted on the other device, give permission for the original device to access it.
Navigate to the song you want to send and hit the button that takes you to the options menu. Choose the option to send your song; depending on the brand of phone it may say "Send" or "Move."
The next menu should ask if you want to use a text message or Bluetooth to move or send the file. Choose Bluetooth.
When prompted on the phone receiving the file, accept it.
Look for an option to browse the contents of the phone. Navigate to the Music or Multimedia folder on your phone.
Navigate to the place on your computer where your music file is kept in a separate window.
Drag the file from its original location to the correct folder on your phone.
Accept the file when prompted by your phone.
Pairing is usually the most difficult part of the process. Make sure you read your manual on both devices if it isn't working for you. If you don't see the menu to move or send your music, your phone manufacturer may not allow it. Check your manual or with your carrier's tech support website. This process usually applies to MP3s and not ringtones.
