Replaced tail light circuit board and bulbs. the turn signal blinks 4 times and then blinks rapidly as if the bulbs are burned out
SOURCE: 99 Dodge Ram 1500 4x4 / nothing but parking lights,no flashers or brake lights......
I found the problem on my Dodge Ram van.. The button for the hazard lights was bad.. I tuned on the hazard lights and only had one side, so i jiggled it and the other side came on. Then I pushed in the hazard button to turn them off and proceeded to check the brake lights, the still did not work so I again jiggled the hazard button and whaaalaaa the brake lights would flicker on and off.. I have a piece of cardboard pushing the button to the side to hold pressure on it keeping my brake light connection until I can get me a new hazzard switch.. Hope this helps..
SOURCE: Right brake light out; tail light works fine
most rear tail lights and turn/stop lights are the same dual filiment bulb. it is possible for your tail light to work and your brake light not to and still have a bad bulb. I would check the bulb first, your brake light works on the left yes? this would mean that the fuse is fine
SOURCE: the brake light doesnt work on my 2001 dodge
You need a new brake light switch. This is very charactoristic of Chrysler products.
SOURCE: rear tail lights not working
If both tail lights are not working it is likely to be a fuse or bad connection under the hood or a connector at the back see if you can trace the wires to a connector and see if it is dirlty or corroded.
