Maytag HAV2558 Top Load Washer Logo
Posted on Dec 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag top load performa, put clothes in , fill up and now the agitator is noisey, looked under washer belt appears to be loose 2-3 inches in play, should I replace belt,or something else to repair noise coming from agitator
Anonymous
Level 2:
  • Expert 85 Answers
  • Posted on Dec 16, 2008
Anonymous
Expert
Level 2:
Answers
85
Questions
0
Helped
30657
Points
187
Thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Can't find where the clutch goes on a Maytag Performa PAV 3300, is it in the transmission?
This washer is a single belt driven model that uses a thrust washer system to release the brake when the motor reverses. In wash mode a 200# spring locks the tub place while the transmission agitates the clothes. The pump cannot remove the water in this direction. In spin mode the the brake is released and the water gets pumped out. Here is a great pictorial that shows how to replace the kit along with a Maytag single belt washer service manual.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
Maytag Performa, Noisey spin cycle, now does not work
the belt may be old and stretched/slipping...if it is stretched and slipping it will cause the squealing .............otherwise, check the pulley for the belt/motor to see if it is okay and the motor itself copuld be worn out if the belt looks ok............be careful, you can get zapped if you touch a wire and also if the motor is burned up it can cause a fire so watch carefully and you should be able to see which of these possibilities are the problem..............
2helpful
Washer was filling but not aggitating,
remove the dispenser in the top of agit . under it is a bolt. remove bolt. it holds it down . if it won't pull by hand then we use a ( agi tamer. this is a split inner tube type/very flat with a split in it . slide under agit and add water and up it comes . 5 min. .. i don't think something is under the agit I belive the trans is failing . but you need to look . . agit needs to be removed to repl trans anyway ..mm
2helpful
2answers
My Maytag washer will agitate without clothes in it but will not agitate with clothes in.
The belt is not doing it's job. It could be that the belt is worn, if so a replacement can be bought from a Maytag dealer. It is also possible that the belt is just not under the proper tension. Maytag motors are mounted in a slide, and tension is applied by a spring. if the grease in the slide gets old and hard, the slide will stick making for a loose belt. To access, you'll need to remove part of the cabinet. Pop the top loose at the front, remove two screws at the top of the front panel, and release the clips at the bottom to remove the front panel. Free up the slide with some light motor oil and re-assemble.
Water problem
1helpful
2answers
"jackhammer" sound coming from my washer
# Balance the load
# Level the machine
# Inspect the water pump for a blockage
# Inspect the coupling
# Inspect the transmission
# Adjust the drive belt tension
# Check the motor bearings
# Check the drum brakes
Maytag > Performa > Drains,Rotates, Fills but wont spin
I had the same problem with you a couple days ago. I disassambled the whole machine and i found out that the belt worn out and the motor also losen so i am looking for parts to replace.
1helpful
Maytag Performa washer Waterlevel/agitator problem
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
Maytag won't spin or agitate
I have had the same problem and found that the teeth on the under side of the agitator had been worn down to nothing... I assume this is from years of over loading (not from me) and so the agitator could not spin any more... i would tighten the bolt that holds th agitator on and it would come loose after a few loads. So my solution was to get a little bit longer bolt and newer plastic washer and tighten it as tight as i could and it seemed to work. Versus buying a new agitator base that would cost about $20-$30 and would have to wait for the part to be ordered. hope this helps
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
