20 Most Recent Maytag HAV3460AWW Top Load Washer Questions & Answers
Hav3460aww
It sounds like the motor is heating up and tripping the overload. The squealing is probably coming from you pump. Tilt the washer back and turn the pulley for the pump by hand and if it make the squeal, replace. If it does not you may have a bad transmission.
5/15/2014 2:52:18 AM • Maytag... • Answered on May 15, 2014
Older maytag wahser water level and agitate cycle
you need to replace the water level switch
4/16/2014 12:50:20 PM • Maytag... • Answered on Apr 16, 2014
Replace brake pads SAV5401aww
drum barely turns by hand--very stiff. Feels like the brake is engaged. Burned and broke the belt. Only discovered brake issue after replacing the belt, which was easy enough. What's wrong and how do I fix it? Searched high and low and can't locate any threads or videos explaining this repair. Thank you
10/7/2013 5:00:41 PM • Maytag... • Answered on Oct 07, 2013
0answers
Noise during wash cycle & got even louder on spin cycle then washer stopped completely
Could be bad belt, or agitator sleeve cracked / or broken. Not catching.
8/8/2012 4:25:43 PM • Maytag... • Answered on Aug 08, 2012
Wont spin or agatiate
Please check for tips from this link:
6/29/2012 11:26:11 AM • Maytag... • Answered on Jun 29, 2012
Will not agitate or spin.
Thanks for choosing FixYa and welcome. If you have a washer that has a weak agitation or no agitation at all, here are some possible solutions. You need to check your belts. Most washers have one or two belts. Check your lid switch. If a lid switch is bad, it can cause the washer to not work properly. Sometimes, they will not work at all. Make sure you check your drive motor. The drive motor controls the spinning, draining, and agitation. Most washers have the reverse motor, meaning the shaft rotates in both directions, clockwise and counterclockwise. It is possible to lose one direction and not the other. Some washers have a clutch that controls the agitation. If it is bad or worn, it may prevent the agitator to work. Most of these washers come from General Electric. You could have a bad motor coupler. They are located on the side of the motor drive inside the washer. It is also possible that you have a bad transmission. Check the agitator itself. You could have a bad spline or two. The splin accompanies the shaft and allows the movement of the agitator. If you rule out all the parts above, you may have an electrical issue or an issue with the control board. It is very important to test each part and make sure it is getting power. If a part is not working and not getting any power, the power loss may be the reason that it doesn't work. You can test the current in the wires with a voltage meter. Thank you very much for reading this tip and thank you for using Fixya. As for the spinning, you need to check the lid switch. It may be bad. It may be your motor drive since it doesn't do both. Have you had draining problems?
5/1/2011 4:51:09 AM • Maytag... • Answered on May 01, 2011
2answers
HAV2360 Maytag does not drain before spinning.
Unlike Whirlpol and Kenmore washers Maytag Washers drain and spin at the same time.
4/10/2011 12:47:20 PM • Maytag... • Answered on Apr 10, 2011
Won't spin after drain seems it has rough spot
Its the water pump- a shiney metal retainer is partially out and rubbing against its housing.
4/10/2011 2:52:12 AM • Maytag... • Answered on Apr 10, 2011
0answers
I have a MAYTAG HAV3460AWW.
this is a common complaint even when we called this the maytag performa washer replace the brake and lining
1/28/2011 5:58:16 AM • Maytag... • Answered on Jan 28, 2011
Machine will not agitate. could it be the water
make sure the lid switch is being activated. you can raise the lid a little and use a butter knife to push the plunger in all the way. sometimes these dont get set in right. double check it. you should hear a little click when you push in.
1/7/2011 11:36:00 PM • Maytag... • Answered on Jan 07, 2011
Washer will not spin
Hi beth. There are actually three possible causes:
1. If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. 2. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician. 3. It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up. Joe Thanks for choosing Fixya!
12/16/2010 9:08:39 PM • Maytag... • Answered on Dec 16, 2010
My washer doesn't spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
12/13/2010 1:05:37 PM • Maytag... • Answered on Dec 13, 2010
How do u find the motor coupler in this model
This model does not have the "motor coupler". It has the belt drive. Here is a diagram of it.
11/29/2010 11:14:00 PM • Maytag... • Answered on Nov 29, 2010
2answers
Maytag HAV2360AWW will not start
Check the back of the lid their is a litel plastic button to make sure the lid is closed see if not broken or stack
or see if drain pomp V belt is out of place or broken
this is the simple way
9/24/2010 4:24:54 AM • Maytag... • Answered on Sep 24, 2010
When filling up on the first cycle, water comes
if the water is coming out thetop off the machine it sounds like your pressure level switch is faulty or blocked.
4/12/2010 9:14:34 PM • Maytag... • Answered on Apr 12, 2010
Maytag HAV3460AWW Top Load Washer Logo
52 questions posted
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
wont spin or agatiate
  • Washing Machines
