Where is the switch located that shuts computer down when the lid is closed?? Could it be in the power button board as it rotates when lid is shut. thanks
Go to control panel /appearence personisation /system security go downtoo power optionsedit plan settings (change when comp goes to sleep /change advanced power settingsbox will open power options work way down to power buttons and lid open that up + on battrey open lid close action you will see do nothing open that up and press shut down
that will shut down youre comp when lid closes
SOURCE: gateway 7422 laptop xp: shuts down randomly no
It seems to be that CPU is overheating. I request you to check CPU fan speed. If needed replace the CPU FAN. it will fix the problem.
SOURCE: My NV52 lap top computer shut down on me the other
remove the battery and try to power on the computer using just the charger. if you can try to use a different charger. if the charger light still goes off when plugging it in your computer then it might mean that there is a short in your motherboard. you can try removing the peripherals (i.e. memory, harddrive, DVD or CD drive, wireless card, battery or modem) to check if it is one of the peripherals causing the short. if you have removed all the peripherals and the system still doesnt turn on or if the power light on the charger still turns off and you have tried the charger on a different computer then it would mean the motherboard is damaged.
laptop will not turn on.
