It appears that there may be an issue with the speed and incline controls on your used Sole F85 treadmill. Based on the information provided, here are a few troubleshooting steps you can try:
1. Check the control panel connections: Ensure that all the cables and connectors between the control panel and the motor control board are securely plugged in. Loose or faulty connections could cause issues with the speed and incline controls.
2. Inspect the control panel buttons: Examine the buttons on the control panel to see if any are stuck or not functioning properly. Sometimes, debris or dirt can accumulate beneath the buttons, preventing them from working correctly. Gently clean the buttons and the surrounding area to remove any obstructions.
3. Test the speed and incline motors: The issue could be related to the motors responsible for adjusting the speed and incline. Test the motors individually by manually applying power to them while disconnected from the control panel. Observe if they respond correctly to the input. If the motors do not respond as expected, they may need to be replaced.
4. Examine the motor control board: Inspect the motor control board for any signs of damage, such as burnt components or loose connections. If you notice any issues, it may be necessary to replace the motor control board.
5. Seek professional assistance: If the above steps do not resolve the issue, it is advisable to contact a professional technician with experience in treadmill repairs. They will have the expertise and specialized equipment to diagnose the problem accurately and recommend the appropriate course of action.
Since your treadmill is a used model and the control issue has persisted for some time, it is possible that the problem is more complex and requires professional attention. A technician will be able to provide you with a more precise diagnosis and help you determine the best solution to get your Sole F85 treadmill functioning properly again.
Remember to prioritize your safety when dealing with electrical equipment, and always disconnect the power source before attempting any repairs or inspections.
Sounds like the button on the panel is stuck somehow, I think this because when you switch the wires this would reverse the polarity to the incline motor.
can you tell if the panel is recognizing the pushing of the incline buttons, like with a beep or light or something? If it didn't seem like it's responding this may be because one button is constantly stuck down.
1)Lube the shaft, gear from elevation motor see the picture 2) adjust the POT a little. 3) see the diagram attached. 4) RUN the software calibration go under the hood motor and see the instructions for troubleshooting, and fix it. God bless you
test the main board, with the output voltage from board for input voltage motor. If there are NOT voltage the board is faulty.replace see the block diagram, how the main boad control about 80% of the machine motion. God bless you
The controller board SCR: Has 2 LED( Light Emitting Diodes):
Up=Lit Up when the Incline Motor is Up. DN= Lit dwon when the Incline Motor is Down. Now if the motor Not goes in any Movement, you must test the relais for control of Incline Motor. Check is there are close and open. If do it. Clean the contact with Special Spray( Cleaner Contact) buy in Radio Schack or whatever Shop that sell Computers and devices electronics. Conclusion the motor maybe is faulty after you did check everything MENTIONED BEFORE. sincerely.
could be bad incline sensor or c/board is going bad. one more try bipassing the board with power to the incline motor fully powered 18volt batt will or higher will move the motorby flipping thr wires on the bat the incline should go up and down. if working ok then check board
try thisSometimes incline motors will get frozen in position and need broke free. Try this: take the motor cover off and take the screw out of the bottom of the incline motor that is attached to the screw assembly. Once you remove the screw you should be able to break the incline motor free. run the incline up and down with the screw still off( laying the treadmill on its side may make this easier). Once it goes up and down (hold the screw so it goes in and out) reattach it then run the calibration described below. If it was just stuck it should work fine.
1. remove safety key 2. press and hold the speed+ and stop keys at the same time 3. Put the safety key in/on and release the keys 4. press stop once 5. hit the incline + arrow and let the incline go the whole way up and down 6. remove safety key and try
If these instructions do not work to fix the incline motor check your main harness running down the right leg for breaks in the wires or a loose connection if nothings found you can switch the red and black wires on the incline motor terminal block and see if it goes down. If it does you know you are only getting voltage to one side of the motor. There is a schematic under the motor hood that tells you what the voltage should be when you press the up or down keys. Use a multi-meter to see if you are getting the correct voltage coming from the console to the motor control board and then from the board to the motor. If no voltage from console-replace console if you have voltage from console but not from board - replace board and finally if you have voltage from console and from board replace motor. You will need to test the voltage both when pressing the up key and the down key.
