20 Most Recent
Nordic Track NordicTrack C900I TREADMILL NORDICTRACK Questions & Answers
Only the plus button on console works nordictrack c900i
Most buttons (all but incline 6 through 12) on my C900i stopped working all of a sudden. Long story short... it was the ribbon cable connections on the back of the control panel. Its 6 screws to get the panel off, and then 10 screws to open the panel. Cut the zip tie so the connection wires can be pulled through the hole in the back panel cover. And then take the iFit module off after you open the panel to allow fully removing the cover. The little white piece on the ribbon cable connectors slides up to allow the cable to slip out. Search youtube if you've never dealt with ribbon cables/connectors - they're very common in electronics. You can also search for how to clean the cables. In my case, simply disconnecting/reconnecting was all I had to - this fixed every button on my panel.
NordicTrack treadmill EXP 1000
Please note that these instructions don't apply to all models of treadmills. Many recent models, including all models with touchscreen consoles, do not have the capability for the user to calibrate the speed.
Speed calibration is a process that is used to correct imbalances in the machine's operating speed.
Please note that this procedure involves pushing the machine to its maximum speed very quickly. Do NOT stand on the treadmill while performing this procedure.
First, you need to enter calibration mode on the console. To do this, press and hold the STOP and SPEED INCREASE buttons (this will be either an up arrow or a + (plus) symbol). While holding these buttons, insert the safety key onto the console. This will cause the machine to go into calibration mode. After this has occurred, you may let go of the buttons and the safety key.
Next, press the stop button once. This will enter advance the screen to the next feature of calibration mode. As said previously, do not stand on the treadmill while performing this procedure. Press and hold the speed increase button. Watch the console. You will see a number on the display that will increase as you hold the speed increase button. Continue to hold the speed increase button until the number changes to "85." This will take the treadmill to its maximum speed, which will also be displayed on the console. Please note that the example below only demonstrates the console displaying "85", not the treadmill's operating speed.
