You may have overwritten your boot.ini file.
To manually edit the boot options file, click Edit. Microsoft
strongly recommends that you do not modify the boot options file
(Boot.ini), because doing so may render your computer unusable.
If both OS's are the same, you should be able to copy and paste the line for XP and simply change the drive letter to the location of the second OS.
SOURCE: dual booting
Boot to Vista. Then
Now you will need to remove Windows XP.
IMPORTANT: for the next step make sure you boot to Windows Vista. Otherwise you could corrupt your computer.
hope this helps.
right click C:\ and select "Format"
SOURCE: Dual Boot XP 32 and XP 64 on different PHYSICAL drives on same PC
So you want to merge those to make it as dual boot system on one harddrive, right? Try these steps:
1. Go to start, control panel
2. Performance and Maintenance
3. Administrative Tools
4. Computer Management -> expand storage, click Disk Management
5. Right Click the drive containing XP32 that you want to use, click format... Choose NTFS then make it as Extended Partition.
6. Reboot your computer and try to see by Pressing F8 if there's an option of what operating system you are going to use.
*Drop me a comment if that works or not so I can assist you further.
SOURCE: i have windows vista home premium on sony vaio
Here is a step by step guide of how to dual boot.
http://apcmag.com/how_to_dual_boot_vista_and_xp_with_vista_installed_first__the_stepbystep_guide.htm
SOURCE: Dual Boot Ubuntu
1st, install windows or if you have already its good .
Then, download Linux distribution that suits You better
Download It and burn into a CD or DVD with ISO file you can use Magic ISO or other manufacturer
then Go to BIOS setup and set 1st priority is the CD or DVD drive and save and exit
and install follow the instruction of linux.
also if you chose capacity of windows or linux is to little dont worry you can make install a partition magic and resize what you like....
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
SOURCE: I need to setup a dual boot computer. I have 2
Do you have both operating systems installed seperatly ? In case of installing another operating system while one is present, the computer would've known to select the one of it by itself or through some menus while startup. If you have installed both operating system seperately than you may need to find out first that both operating system are able to boot with some menu choice from the startup. To dual boot computer one system has to set as primary while other as extended partition using some Harddisk utility like FDISK. If you need to reset the partitions make sure that both systems works together as dual boot. Win XP, Win98 works as dual boot, WINXP , LINUX works together , but WIX 95 and WIN 98 may not work for dual boot systems.
Both OS's are WinXPPro. Would rather not load OS2 if possible for different reasons.
Thanks Chuck for you information. Unfortunately, in the default operating system list, OS2 (D) isn't showing up so I can't choose it to be the system I want to start with.
As far as editing the boot options file, both OS's are the same however in the default OS, it doesn't show any drive letter although it is C drive. Never worked with notepad and if the 2nd OS (D) isn't ever there, not sure how I would copy and paste with a changed drive letter.
So try this:
Use the previous instructions to edit boot.ini.
If your other OS is on a separate drive, change the rdisk(0) to rdisk(1) for the other OS. So the final boot.ini file might look something like this...
[boot loader]
timeout=5
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="XP OS1" /fastdetect
multi(0)disk(0)rdisk(1)partition(1)\WINDOWS="XP on Drive D" /fastdetect
Sorry Chuck, haven't tried your suggestion yet. I've heard when you start messing with the boot. ini., it can screw up your puter so am waiting til I have time to work on that problem in case I screw things up lol. I'll let you know how it works out though and thanks again.
