20 Most Recent Dell Vostro 1510 Laptop Questions & Answers
I want my dell vostro 1510 function key turn off
Ok, it's handy to keep but ok. Make sure you press and hold these keys till it changes. Number Lock+Fn+Delete and it should turn it off.
Hope this helped. Good Luck!
2/2/2022 5:03:26 PM • Dell Vostro 1510... • Answered on Feb 02, 2022
Dell vostro 1510 bluetooth
Internal Bluetooth card, service manual link: http://support.dell.com/support/edoc....htm#wp1179838
Make sure you have the correct drivers installed for your OS and make sure that both wireless and bluetooth are enabled in the system setup. To do this, boot into the system setup by rebooting your computer and tapping on F2. On the left pane, look for Wireless (navigate using the arrow keys) then hit Enter, then navigate to bluetooth, make sure the setting is set to ENABLED (complete instructions for navigations and options selections should be illustrated on the lower portion of the setup screen). Once ENABLED, reboot into your OS and go into to control Panel open the bluetooth icon, make sure your external Bluetooth device (phone/smartphone, etc.) is set to discovery. Search for the device to see if it is detected.
The Bluetooth Icon will appear in the systray (lower right corner of your desktop task bar. Right click on that icon and then select the option you need. Make sure you enter the same device code in both the laptop and the device you want the computer to connect to. Hope this helps FixYa! Leave some feedback and a testimonial if you find these instructions helpful.
5/19/2019 5:36:44 AM • Dell Vostro 1510... • Answered on May 19, 2019
My Fn key is locked
I have a similar issue. I used the Fn and Num Lock keys, hitting them together. It released the keys.
11/1/2018 11:50:06 PM • Dell Vostro 1510... • Answered on Nov 01, 2018
I got password dell vostro
send me service tag ill send u password
9/7/2018 11:36:52 AM • Dell Vostro 1510... • Answered on Sep 07, 2018
Sd card will not eject from dell vostro 1510
hi there. Get a fine sewing pin and put a little hook on the end (about 2mm hook) get the hook in behind the card and gently tug. You may have to use a second pin without hook to guide the card up or down. I used sewing needle to pry it out--picking at it from the front on the sides and bottom. (It's made of soft plastic and I don't mind if I damage it.) Eventually it came out. YEA! take some tweezers and pull it out of the card reader thats how I got mine out A thin pointed knife and 1 chopstick on each side - ejected in less than 30 seconds.... this is all i could find out,hope you get it sorted.
11/20/2017 12:51:16 PM • Dell Vostro 1510... • Answered on Nov 20, 2017
Dell Vostro 1510 (Win 7) - Can't enable/disable the Touchpad
There is an option to disable the internal touchpad when you connect and external mouse. Please check the screenshot attached. screenshot_1-kjbx0rymwrgfwv3uhf2b4zpz-3-0.jpg
5/6/2017 6:37:54 AM • Dell Vostro 1510... • Answered on May 06, 2017
How do I fix itunes unknown error (-50) on a dell vostro 1510 with windows 95?
Are you posting questions just to be a pain? The Dell Vostros 1510 was released in 2008, it was never designed for Windows 95 and I seriously doubt they would have created W95 drivers for the hardware. Dell Vostro 1510 Review NotebookReview com The new iTunes is not 10.6.3, that was released in 2012 Apple releases iTunes 10 6 3 and even if it was, iTunes was never released for W95, the first Windows OS it supported was Windows 2000 History of iTunes
3/20/2017 8:47:17 AM • Dell Vostro 1510... • Answered on Mar 20, 2017
How to build Pentium i3
It would be better for you to buy a new laptop. I would take a person with you who knows somethings about computers. You should go to Best Buy, Staples, etc. to look around. Even a laptop in the $500 - $600 dollar range would be way faster than what you are currently using. Complete Guide to Buying New Laptops 2016 Laptop Buyers Guide
9/7/2016 6:00:05 AM • Dell Vostro 1510... • Answered on Sep 07, 2016
The copy of windows did not pass genuine windows validation
Try this program:http://www.softpedia.com/get/Tweak/Unins... and disable automatic updates: START-> CONTROL PANEL-> AUTOMATIC UPDATES -> CHOOSE THE OPTION -> Turn off automatic updates <- ;-) ....
7/25/2016 8:06:33 AM • Dell Vostro 1510... • Answered on Jul 25, 2016
Forgot password to unlock laptop
what op system is on laptop. you may try using setup disc boot from disc change password leeve it blank then restart after that it should boot with out asking for password , after restart go to users set new password. hope this helped.
2/27/2016 10:09:10 PM • Dell Vostro 1510... • Answered on Feb 27, 2016
My dell wont get past the login in screen without the start up repair and i dont have a disk
You'll have to get the restore CD's in order to reinstall the operating system
1/15/2016 6:24:25 AM • Dell Vostro 1510... • Answered on Jan 15, 2016
4answers
"[9]" labeled status light blinking and no display
open the case then locate the memory and make a clean all pin connectors of memory using a paper eraser..
11/7/2015 6:50:57 PM • Dell Vostro 1510... • Answered on Nov 07, 2015
STARTUP REPAIR
Hello, Go into safe mode, do that by hitting f8 when the screen first comes on repeatedly and try repair. Most of the time this doesn't work and you have to reload your application cd's.
11/6/2015 2:49:49 AM • Dell Vostro 1510... • Answered on Nov 06, 2015
2answers
Hi, I have bought this dell vostro 1015 laptop
It sounds like your hard drive has gone bad. As this is a laptop you can try to reseat the hard drive, if that does not help then it might be a case of hard drive crash.
7/8/2015 8:49:26 AM • Dell Vostro 1510... • Answered on Jul 08, 2015
manual
Microphone driver for dell vostro 1510
original drivers can detect microphone here is the link to download. http://www.dell.com/support/home/us/en/04/product-support/product/vostro-1510/drivers
3/30/2015 8:53:49 AM • Dell Vostro 1510... • Answered on Mar 30, 2015
3answers
How do i diy update my dell vistro 1510?
In terms of hardware, you would only be able to upgrade the Memory, Hard Drive, and possibly the CPU. If you want to upgrade the operating system, you could put windows 7 or 8.1 on there. But your best bet would be to get another laptop. .
3/17/2015 5:10:44 PM • Dell Vostro 1510... • Answered on Mar 17, 2015
Lost my volume icon on computer
click on START and type (volume) in the box that appears right above the start button. from the list that appears click on (show/hide volume icon) or something like that, and change the box of the volume icon to (on).
3/6/2015 5:33:45 PM • Dell Vostro 1510... • Answered on Mar 06, 2015
How do I fix inoperable devices on Dell Vostro 1510
Go to Dell Support page, and then use their online diagnostic to determine what issues your computer is having. Before you start, copy down your service tag number so you can easily enter it. If you need to download drivers, you can download them from the support page. Use the control panel/devices manager to identify any components and use the settings panel to turn them back on or update drivers. A bit of persistence is needed, but you should be able to restore all hardware settings.
2/27/2015 4:56:12 PM • Dell Vostro 1510... • Answered on Feb 27, 2015
Dell Vostro 1510 Laptop Logo
480 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Vostro Dell
  • Vostro Dell
Most Popular Question
turned computer today typing backward
  • Computers & Internet
