20 Most Recent Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Questions & Answers
Internet broadband connection is much more faster because it is directly connected via physical connection from the modem (typical setup for home use). But now a days wireless internet can now compete with DSL thru a 3G/HSPDA network. In our country we can have a maximum bandwidth of 2.5Mbps using 3G wireless network.
Answer:
Yes you can speed up your connection using your phone as a modem but you need to consider some aspects.
  • your phone is a 3G capable phone
  • you have 3G network signal that an indicator "3G"can be seen next to the signal meter of your phone.
  • your network provider has 3G services.
What happen to you most likely is that your are connected using only a GPRS/EDGE. This is equivalent to a dial-up with maximum of 56kbps transfer rate. There is a great gap between the two if you compare it.
I already tested mine with maximum receive/downlink of 2,501 Kbps. I was really amazed.
Hope this things help you. If it does, please rate me.
regards,
-engrkoiled-
Lenovo 3000 N100... | Answered on Jun 07, 2018
Contact Lenovo's customer service and report the issue, they may be able to repair the problem
Lenovo 3000 N100... | Answered on Aug 03, 2017
Log on with another administrator user profile or if you don’t have any other and you are the only user do the following:
1. Turn off computer
2. Turn on computer and press F8 while you see the DELL logo
3. On the Windows Advanced Options select Safe Mode
4. Open the Start Menu and type Regedit on the Start Search field
NOTE: If unable to boot to OS even in safe mode then boot to WinRE, go to command prompt - type regedit.exe to perform below steps:
5. Go to the following entry:
a. HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Profile List
6. There you will find the following information:?ui=1&attid=0.3&disp=emb&view=att&th=1199b59e24dfc199
7. On the “.BAK” file you will find an entry with ProfileImagePath with the name of the user.
8. Delete the repeated entry that does not contain “.BAK”
9. Right click on the other entry and select Rename. Delete the extension .BAK for the original entry.
10. Exit Regedit
11. Restart computer.
Lenovo 3000 N100... | Answered on Apr 05, 2016
Simplest way is to use a live cd to boot and then right click the hard disk and format.
then boot using setup dvd and make fresh install
Lenovo 3000 N100... | Answered on Feb 29, 2016
If you have the OEM Lenovo XP disc are you have to do is insert and follow the instruction. If you are using off the shelf software, then switch the BIOS SATA to compatibility mode, and boot from your CD drive with the disc in it, and format the harddrive followed by installing the software.( like Windows XP or the Vista)
Lenovo 3000 N100... | Answered on Dec 29, 2015
hi,
mail the red code to satyendra@channel-technologies.com and they will send the gift to u
Lenovo 3000 N100... | Answered on Nov 02, 2015
Check and change Battery and Charger
Lenovo 3000 N100... | Answered on Aug 17, 2015
Please change Tha lenovo Battery
Ur Battery is Problem Pls change tha Battery
1. Check Ur Laptop Charger and replace ur charger
the problem is continue go to 2nd step
2. change the laptop Battery
Lithium Ion batteries do not suffer from charging problems, but like all battery technologies they do wear out over time.
Lenovo 3000 N100... | Answered on Jun 21, 2015
Please check on the website from where you have downlaoded it.
or
below site has some keys try them:
http://freeinternetzones.blogspot.in/2013/05/free-ms-office-2010-and-2007-product.html
or download keys from torrent (for this u need to install torrent client like utorrent on your desktop):
http://pirateproxy.net/torrent/7656949/MicroSoft_Office_2007_With_Key
Regards,
Rahul
Lenovo 3000 N100... | Answered on Mar 20, 2015
TFT stands for Thin Film Transistor
Lenovo 3000 N100... | Answered on Mar 18, 2015
how to format lenovo g560 by one touch recovery key?
Lenovo 3000 N100... | Answered on Dec 13, 2014
sometimes 3rd-party battery MFR's do not produce batteries that are FULLY compatible with the laptop; and some laptop MFR's are built to reject non-OEM replacements. It is also possible that you have a bad battery.
Before purchasing a laptop battery, always read the reviews to look-for any that indicated a problem of not recognizing, like you have now.
To answer the question though....if it does not recognize it now, that will not change in the future by any means at your disposal, (like installing new software.)
Genuine Lenovo Battery not Chinese Fake or Aftermarket : $50
New Original Lenovo G430 G450 G530 G550 G555 Battery L08S6Y02 42T4725...
Lenovo 3000 N100... | Answered on Oct 30, 2014
Hi..
First you have to download this One Key recovery application from Levono's official site - lenovo.com. Just run the application and the installation process should help you thru..
I hope this helps.. please vote.
Thanks - billa
Lenovo 3000 N100... | Answered on Oct 27, 2014
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
491 questions posted
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
3000 Lenovo
  • 3000 Lenovo
Most Popular Question
when start video calling from facebook
  • Computers & Internet
