20 Most Recent Lenovo 3000 Y410 Laptop Questions & Answers
Hi raj,
I see that you are having a Bluetooth issue finding he option sending and receiving Bluetooth transfer options.
On your system whichever windows you may have you can see Bluetooth,
  • Click on Start then click on All Programs, look for accessories
  • Click on accessories it should show you the Bluetooth icon under Accessories if you click on it it will give you the option to send and receive using Bluetooth.
I see that you installed the driver for your Bluetooth to see if it installed properly check device manager, you should see Bluetooth under Network Adapters, if it's not there then the installation was not successful or maybe it just did not install correctly, try reinstalling again.
  • You can also try download an application that can utilize your Bluetooth device for example Blue Soliel that is a good Bluetooth Application that I personally use, you may just need to purchase the program online to be able to use the full functionality of the application.
I hope that his will be helpful regarding your concern, have a nice day.
Lenovo 3000 Y410... | Answered on Jan 07, 2017
Update all drivers from the manufacturers web site FOR FREE! Be wary of driver update programmes, they usually give you incompatibilities.
Lenovo 3000 Y410... | Answered on Jul 28, 2016
Generally, your PC can be unlocked by pressing CTRL+ALT+DELETE and entering your account password.
Lenovo 3000 Y410... | Answered on May 13, 2016
If it is the same on an external screen than you have a GPU issue. If not replace the screen.
Lenovo 3000 Y410... | Answered on Apr 15, 2016
Hi. First things is you should have a wireless router there or you are at a certain hotspot where there is a free wireless internet access e.g Starbucks. Procedure below:
  • 1 Purchase a wireless router that fits your needs and price range.
  • 2 Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
  • 3 Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
  • 4 Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
  • 5 Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
  • 6 Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
  • 7 Click on "Properties."
  • 8 Select the "Wireless Networks" tab.
  • 9 Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
  • 10 Click on "Configure" when you see your network's SSID in the "Available Networks."
  • 11 Enter your network's SSID and WEP key.
  • 12 Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
  • If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
    Lenovo 3000 Y410... | Answered on Apr 12, 2016
    most likely, the drivers on the CD are not compatible with Win 7. try to download the drivers from the Lenovo support site. look for a compatible Win 7 drivers for your audio controller.
    Lenovo 3000 Y410... | Answered on Dec 29, 2015
    Good luck with that, windows 7 is better than vista.
    Lenovo 3000 Y410... | Answered on Dec 28, 2015
    its usually becouse of the upgrade to windows 7 that you need to reinstall the sound drivers. please first download theaudio bus drivers then install the audio drivers
    Lenovo 3000 Y410... | Answered on Dec 20, 2015
    Hi
    I think you need to go to the lenovo website to download new drivers for windows 7 hopefully they may some drivers for you
    http://www-307.ibm.com/pc/support/site
    If you have upgraded the Laptop from Windows Vista to Win 8 , Did you do a Hardware compatibility test? You may be in for bit of a mess. Take a look at this: http://howto.cnet.com/8301-11310_39-57390888-285/check-your-hardware-for-windows-8-compatibility/ The driver's are another issue, sometimes you can use Win 7 drivers, change compatibility, and modify the drivers to work with your hardware. I have done it , and it can be quite a pain, and quite frankly not worth it. I would suppest Win 7. When you "jump" two OS's ,Vista to Win 8, it doubles your fun.
    Lenovo 3000 Y410... | Answered on Sep 17, 2015
    i have install windows7 in my y410 laptop and the sound driver is not working in it.it shows an error massage while i am trying to install the driver.
    hi there wait a moment please
    Lenovo 3000 Y410... | Answered on Jul 15, 2015
    The password is normally on a label on your router.
    Lenovo 3000 Y410... | Answered on Feb 28, 2015
    Go to https://messaging.bigpond.com/?cid=Aside-sales-login-module and bookmark it in your browser.
    Lenovo 3000 Y410... | Answered on Dec 03, 2014
    From Windows 7 and up, for all hardware that is certified with Microsoft, you can download the drivers from Microsoft. Lots of hardware is recognised when connected and will initiate a download from Microsoft. But not all hardware will do so and not all hardware is compatible (same as not certified by Microsoft from Windows 7 and up) with the new operating systems.
    Most things that worked fine with Windows XP and or Vista, can fail with Windows 7 and 8, because the factory that made the hardware in the first place does not ask for certification with Microsoft for their old Hardware. They only spend time and money to get their new hardware certified on the new operating systems. So to make sure your hardware is compatible with the OS. Check the manual and find out, what you have to do so it will work on your computer.
    There is no special Lenovo driver, unless the hardware in your laptop is made by Lenovo. In that case the driver will be on your computer after you installed Windows 7. Perhaps you call something a driver but need something else?
    Lenovo 3000 Y410... | Answered on Nov 02, 2014
    Check to see if you have pressed the Num Lock key. it might be stuck, in whihc case you can try pressing it repeatedly and possibly spraying compressed air and/or electonics cleaner under the keys.
    Lenovo 3000 Y410... | Answered on Aug 18, 2014
    Hit F8 during the boot process to bring up special boot features like Safe Mode. With Windows 8 you can open a search bar and type "Startup". Select Change Advanced Startup Settings". Select Safe Mode. Reboot.
    Lenovo 3000 Y410... | Answered on Jun 01, 2014
    All touch pads work of the capacitance in your skin. The device requires a driver software to activate it. Open the Wondows Control Panel and look under DEVICE MANAGER before doing anything. Look for a yellow exclamation indicating a hardware error. If one exosts then open it by clicking on it and make sure the driver is installed and is working (which Windows will tell you when you check the driver software itself) and update or replace as necessary.
    If you can provide the Windows version then I can give you specific keystroke insturctions to do the above if you are not familair with Control Panel
    Lenovo 3000 Y410... | Answered on May 18, 2014
    Lenovo 3000 Y410 Laptop Logo
    601 questions posted
    Top Lenovo Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Alun Cox
    Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
    View Most Popular
    3000 Lenovo
    • 3000 Lenovo
    Most Popular Question
    unlock keyboard lenovo laptop
    • Computers & Internet
