MY HARD DRIVE IS FULL, LOST INSTRUCTION BOOK, NEED TO KNOW HOW TO TRANSFER DATA TO LAPTOP OR IS IT AS EASY AS HOOKING THE CORDS TO BOTH AND ITS AUTOMATIC?
Connect your camera to your PC via USB, your camera will ask you what to do, choose back-up, connecting for the first time, your PC will prompt you to insert CD, follow the instructions your PC tells you until its done. Good luck
Connect the camera to your pc using USB CABLE.
once you connected the camera, open the LCD display and turn on the camera "on" button.
then choose backup option.
It will then load your camera hard drive as a external hard drive on your pc. :P
It is very simple, just re-connect the device and restart the process for remaining data and simultaneously check if you have lost any data or not. If you have lost your data then you have to show your machine to an expert for Recovering Data from Hard Drive.visit us http://www.maidenheaddatarecovery.co.uk
Easy, just hook up old drive as secondary and new drive as primary. Copy what you need from the secondary onto the primary. When you are done, just disconnect the secondary drive and enjoy your new one.
If the Repair fails, then you need to re-install the Operating System all over again. If you want to save existing data, such as pictures, documents and music; you must remove the hard drive from the laptop and attach it to a PC. There are Laptop cords with attachments that connect laptop drives to a USB port on a PC. You will have to use one of these cords and get the hard drive open on the PC Desktop. Once open, transfer the data to the file (make one on the PC Desktop) and save it. When complete, you will need to format the old laptop drive so it can be used again in your Laptop. If you don't care about saving your laptop data; then simply put the Windows Operating disk in the DVD and run from your laptop, installing a full new version on the existing hard drive. Windows will seek the Hard Drive for you and prepare it for new start.
It seems that your WD hard drive is corrupted so you are unable to access the stored files. But there is no need to worry since it is very easy to recover data from corrupted WD partition by using Western digital partition recovery software. Couple of days ago, even I was stuck under similar problem I tried this software which really helped me to retrieve all my lost data.
If your xbox dropped while it was running, then more than likely the hard drive is damaged, and you won't be able to recover the data.You may be able to disassemble the Hard Drive and connect it to your PC or laptop by following the instructions here:
http://www.youtube.com/watch?v=KQBvAWgLrP4 after that you may be able to recover your saves. You can then replace the hard drive or transfer the recovered files to a new xbox Hard drive, but you will need the data transfer cable for this.
have the files been deleted from the laptop? if not i would simply do a fresh format on the external and re migrate data. if they are then you can get software such as undelete or recover my files to restore your deleted data off of your laptop drive.
