20 Most Recent Hitachi Deskstar 7K1000.C HDS721010CLA332 - Hard drive - 1 TB - internal - 3.5" - SATA-300 - 7200 rp... SATA II Questions & Answers
Repair broken
Easy, just hook up old drive as secondary and new drive as primary. Copy what you need from the secondary onto the primary. When you are done, just disconnect the secondary drive and enjoy your new one.
1/3/2014 7:52:00 AM • Hitachi Deskstar... • Answered on Jan 03, 2014
How do i transfer data from hard drive if it is vroken
Hi, if you can hear the drive spinning up but then making a clicking noise this means the heads have failed, this would need to be opened up (ideally in a clean room), if the platters are okay you can replace the heads... but if your data is precious to you I would reccomend sending it to a data recovery company Digital Recovery (www.digitalrecovery.co.nz) are fairly good.
12/30/2013 11:31:24 AM • Hitachi Deskstar... • Answered on Dec 30, 2013
I have and hitachi HDS721010CLA332,
if not need you second operating system, format your second Hdd, if it IDE, see that in behind hdd it will be switched,,slave,,.
6/1/2011 2:17:46 PM • Hitachi Deskstar... • Answered on Jun 01, 2011
One of my 7K1000.C drives has extensive but minor
The best way to fix & prevent it would be to move everything off of it and wipe the drive clean and do a full format, not a quick format. The other thing could be, depending on what type of system you have and if its overclocked it can cause data corruption if the Pcie frequency is set above ~110. I have three of these without a single problem, with about 8,200, 8,080, and 5,400 hours on them.
5/24/2011 2:05:51 AM • Hitachi Deskstar... • Answered on May 24, 2011
Hi, I have problem here. I just bought Hitachi
The short answer is the drive is having trouble calibrating itself, and should be sent back under warranty for replacement.
There are things you could try to recover the unit, but why risk voiding the warranty only to wind up with a questionable drive afterward?
3/17/2011 2:33:22 PM • Hitachi Deskstar... • Answered on Mar 17, 2011
Usb connection
Update your ms Drivers and Service pack.
1/27/2014 8:43:24 PM • Hitachi Deskstar... • Answered on Jan 27, 2014
0answers
Hitachi 50hyt62u H can I add a removable drive as I have a slot in Back for one, and if so where do I get one
You should be able to buy an external USB drive (or thumb drive) at any electronics store. You can connect a USB hard disk drive or USB memory stick to your TV by using the USB inputs of the TV. This feature allows you to play files stored in a USB drive. 2.5" and 3.5" inch (hdd with external power supply) external hard disk drives are supported. IMPORTANT! You should back up your files before making any connections to the TV set in order to avoid any possible data loss. Manufacturer will not be responsible for any file damage or data loss. It is possible that certain types of USB devices (e.g. MP3 Players) or USB hard disk drives/memory sticks may not be compatible with this TV. Quickly plugging and unplugging USB devices, is a very hazardous operation. Do not repeatedly quickly plug and unplug the drive. This may cause physical damage to the USB player and USB device itself. Do not pull out USB module while playing a file. Media Browser Menu You can play photo, music, and movie files stored on a USB disk by connecting it to your TV and using the Media Browser screen. To do this, perform the following: Connect a USB disk to one of the USB inputs located on the side of the TV. You can connect two USB devices to your TV. If both USB devices include music, picture or video files, USB selection OSD will be displayed on the screen. The first USB device connected to the TV will be named as USB Drive1. Select a device by using up or down arrows and press OK
11/30/2019 1:10:18 PM • Hitachi... • Answered on Nov 30, 2019
How to connect my Mac book pro to a Hitachi projector
You will have to use the HDMI port on the mac. provided you have a HDMI input in the projector
11/26/2019 12:41:17 AM • Hitachi... • Answered on Nov 26, 2019
HiTaChI pRinTeR inStaLlAtIoN cuStOmEr sErViCe nUmBeR $1.{877}*{76.9}*{09.69}*#$ 24/7
BENJAMIN, Your message does not qualify as a question or query for a problem, try somewhere else DO NOT MAKE THIS SITE WITH YOUR GARBAGE Take your GARBAGE to another Side Your message qualifies as SPAM
11/7/2019 5:39:59 AM • Hitachi... • Answered on Nov 07, 2019
My Hitachi XL500 external hard drive is not showing anywhere on my computer. I also do not believe any power is getting through to my hard drive. Please help
buried in endless spam are you. does it fail on 2nd PC???????????????????????????? but yes, I am the MVP of external HDD< I build my own. Have over 5 here for Backups . lots of causes, for sure bad drive, or missing drivers.. bad HW hardware or BAD software SW. Missing 12vdc 2amp power pack>, lost or using wrong one. when pack above does the HDD spin? usb connected to PC. NO PC stated, NO OS stated, windows/chrome/Linux/android? its at lease 10 years old , see posts back that far. not good old HDD,this old. sold during W7 era. 2009. The drive has 3.5" HDD that needs lots of power (Amps) to start up that big motor inside, and is first thing to learn . 2amps it needs, ok? so if pack is missing it will never startup on any USB port, not rated for 20x standard USB load factors. some laptops only do 0.1amps (100mA) and are useless to startup any hdd motor of any kind. see why here. and see a better extremal solution cheap.! $10 http://www.pcdied.com/external-hdd.html
7/3/2019 1:28:14 PM • Hitachi... • Answered on Jul 03, 2019
Hitachi Deskstar 7K1000.C HDS721010CLA332 - Hard drive - 1 TB - internal - 3.5" - SATA-300 - 7200 rp... SATA II Logo
Popular Tags
13 questions posted
Top Hitachi Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Deskstar Hitachi
  • Deskstar Hitachi
Most Popular Question
repair broken
  • Computers & Internet
