I have 2 CY199D monitors. About a month ago unit 1 would not come on and the blue power lamp flashed from off then amber then blue in some sequence. Pressing the power button has not effect, won't go on or off. The screen is completely dark with no sign of life. I called for support but I-Inc , now called Hanspree (or something like that) said they though the board was probably defective and the part is 1/3 of the unit cost. It was 1 month out of guarantee. They said that there is nothing that can be done to reset the unit without the display up.
OK a bad unit. Today unit 2, which is less than 2 years old and also out of guarantee, did the same thing. I turned the monitor off because I have been away and when I turned the system on I forgot to turn on the monitor. The computer was up when I turned on the monitor but the display did not light up and now the power button no longer functions and the lamp does the same thing. I tried disconnecting the power for a while but to no avail.
I was not present when the first monitor quit but I suspect that the sequence was the same.
Anyone have any suggestions besides throwing the monitors away and staying away fron I-Inc?
I experienced exactly the same thing 10 months after buying the monitor. Came back from being out of town, powered up my computer and the LED indicator changes from amber to blue and the screen is blank. Tried the monitor on several computers and all were the same result. Others who have experienced this indicate it is a firm ware update. If someone has the updated EEPROM there are EPROM burners out there that can copy the program to a new EEPROM. The company where I worked some years ago had one, they are pretty common.
Mark in KC
I have sucessfully repaired three I-Inc CY199D monitors which all had the same problem.
The monitors program is stored in a 24LC16B which is a 16K serial EEPROM in a SO8 package.
The bad part is you have to remove this eeprom to program it as it is write protected on the board and you will need a serial EEPROM programmer and an uncorupted program I have all the above.
If there is enough interest I could offer preprogrammed EEPROMS or a repair service for the graphics card..
could you get in touch with me to solve my I-INC CY199D problem on your post 2 yrs ago you mentioned you have pre-programmed eeproms ,I am interested in buying one..
My email is:[email protected]
Thks Serge
Is it possible to share the bin file..?
Thanks
Surej
I solved the problem by just changing the eeprom from one 7 inch screen and it worked straight away.. so I think there is not data in the eeprom for the screen to switch on it rather saves all your settings to it.. so a fresh eeprom might work as well..I'll change to a new eeprom and test again
regards
Surej
Adrian- how do i get in touch with you for your help with my CY199D eeprom? how much would you charge and how do we get this handled and do you still'hav the the ability to reflash the eeprom's?
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
I have the same monitor and yesterday morning it was working fine. Turned the computer off and when I turned it on later in the day, the monitor remained black. I just hate throwing this stuff out but repairs often cost nearly the same as a new whatever.
I had this when I first bought the two monitors. I sent one back for warranty repair and it came back. I have had them for about two years now and today one of the two crashed.
I have the same monitor problem which is about 18 months old. I have two other different brand monitors and both are still in great working order after several years old. I took this I-Inc monitor apart and found the mainboard was out of order. It has no burnt out electronic components found and more likely is the EEPROM problem for the reason the power switch has no effect because it is controlled by the mainboard. I-inc refused to sell the mainboard separately. Can anyone tell me where to a new mainboard for this CY199DP or how to change that EEPROM.
Peter in Calgary
Between home and work I've bought five of these 19" I-Inc LCD's and now I've had three of them fail with this exact problem. Good deal or not, I will never buy anything from I-Inc again.
