20 Most Recent Samsung 204T 20" LCD Monitor Questions & Answers
How do i turn it on
Hi there, On pg 12 of the manual indicates the Power On/Off switch is beside the power cord plug in. 25550220-qntx1xz4uswqeot4smlmd4ho-5-0.png
3/11/2015 2:57:18 AM • Samsung 204T 20"... • Answered on Mar 11, 2015
How do I fix color on screen it is pink
You have bad caps in your monitor
11/18/2014 7:57:49 PM • Samsung 204T 20"... • Answered on Nov 18, 2014
Turn on the monitor one
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/ Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
9/23/2011 6:20:46 AM • Samsung 204T 20"... • Answered on Sep 23, 2011
My LCD screen got accidently
whit a hairdrayer
2/15/2011 6:51:39 PM • Samsung 204T 20"... • Answered on Feb 15, 2011
Screen has blue tint, and is dark. No idea how it
thats a lojic cord problem,u can replace lojic cord r memory
1/30/2011 4:56:47 PM • Samsung 204T 20"... • Answered on Jan 30, 2011
When i boot my computer,
It may have dying power supply due to bad caps.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/ Post back what you see inside so we can guide you further and it will help out other people in the future also.
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
12/7/2010 1:29:43 AM • Samsung 204T 20"... • Answered on Dec 07, 2010
I forgot my password to my computer now I can't
Turn on your computer, go into safe mode (press the F8 key on top of your keyboard). Select Safe Mode (either one, doesn't matter). From there, go into your User accounts and either delete the account and/or change the password thats all
11/5/2010 8:56:46 AM • Samsung 204T 20"... • Answered on Nov 05, 2010
The monitor was appearing to
More likely to be bad caps with leaking/bulging top, that will be the first thing to look for.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
9/14/2010 12:13:55 AM • Samsung 204T 20"... • Answered on Sep 14, 2010
Only displaying 10 x 10
It sounds to me that you have the resolution on the wrong setting. Go a a clear space on your desktop, right click, and select properties. When that opens go to the settings tab and change the screen resolution to 1600 X 1200. This is the native setting for the monitor. If that doesn't fix the problem continue changing the screen resolution until you get one that works.
9/3/2010 9:03:10 PM • Samsung 204T 20"... • Answered on Sep 03, 2010
I turned off my pc, with no problems, and when I
Check that the video cables are connected properly and secured with the screws.
8/28/2010 2:40:04 AM • Samsung 204T 20"... • Answered on Aug 28, 2010
I turned off my pc,
Check that the video cable is seated properly and secured to the port with the screws.
8/27/2010 2:55:14 AM • Samsung 204T 20"... • Answered on Aug 27, 2010
My computer screen got water on it and now is
If it was "plain" water, it might dry out without leaving any residues. If it was coffee-with-sugar, or soda-pop, the sugars will cause problems.
All you can do is to let it dry out, and hope.
6/15/2010 1:52:51 PM • Samsung 204T 20"... • Answered on Jun 15, 2010
Randomly will not lock on to a signal, it cycles
Strange problem like this can be caused by unsteady power supply, check for bad caps first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
6/13/2010 6:39:49 PM • Samsung 204T 20"... • Answered on Jun 13, 2010
Samsung 204T no longer displays
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
6/13/2010 7:23:48 AM • Samsung 204T 20"... • Answered on Jun 13, 2010
Monitor will not come on, blue light just
Check for leaking/bulging caps in the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
6/2/2010 4:49:36 AM • Samsung 204T 20"... • Answered on Jun 02, 2010
WON'T STAY ON...
5/21/2010 6:31:53 PM • Samsung 204T 20"... • Answered on May 21, 2010
Hello, my screen shows
This happens since you are using pirated version of windows.In order to avoid this follow the below steps
1. Before doing anything serious try restoring your system. If the problem is occurring after the Windows Update then System Restore will surely help.
2. But if it does not then do try this, launch Windows Task Manager.
3. Locate the process “wgatray.exe” and end it.
4. Log in into the Safe Mode and delete the file WgaTray.exe from c:\Windows\System32
5. Also delete the WgaTray.exe from c:\Windows\System32\dllcache
6. Type regedit in Run to open Registry Editor, navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify key.
7. Delete the folder WgaLogon and all of its contents.
8. Restart the PC normally.
5/11/2010 2:12:04 PM • Samsung 204T 20"... • Answered on May 11, 2010
Samsung 204T 20" LCD Monitor Logo
50 questions posted
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Computers & Internet
Most Popular Question
data manager stopped working problem
  • Computers & Internet
