I just replaced the drum cartridge in my oki b6300 laser printer and it keeps telling me to replace it . what can I do?
SOURCE: what does the following error msg mean on a Oki B6300 printer
la verdad nc a lo qt refieres o mejor dicho no t entendi la pregunta......
SOURCE: OKI B6300 Drum problem
Hello, com_jedi. I would suggest you contact the OKI Customer Support line in order to address this issue. The phone number is 1-800-654-3282 (800-OKIDATA). For your model unit you would hit options 1 then 4 to get to mono support.
It is possible that you purchased a defective consumable and OKI warranties them for 90 after the date of purchase. If this is a new drum/toner it may need to be replaced to determine if it was a bad chip in the cartridge or if there is some other issue with the unit that is causing the error.
It is also possible there is a misalignment with the sensor that is located under the drum unit. A support tech can walk you through the troublehshooting as it would be a bit difficult to do here.
I hope this helps!
SOURCE: OKI B6300 DRUM/TONER
try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
