20 Most Recent
OKI C5100n Laser Printer Questions & Answers
OKI c5100 Printing GREY instead of BLACK.
Not able to print a status page. Tried holding down menu 5 sec and no output. I searched the menu and am not able to find how to print status page. I did print out a demo page and the black is great but when i print out text (like the entire menu map) the black is grey. Let me know if there is anything else I can do.
Errors poped up after routine cleaning of C5100N
Greg,
The classic machine gun type sound is usually a seized drum. You can tell which one it is by simple taking out each drum in turn and when you close the lid if there is no click then the drum not in the printer is the offender. The black drum is missing possibly because you have not located the belt correctly. Usually the right blue lock on the belt is actually not locking the belt as the belt is not laying flat. Take the belt out and refit making sure that the projections that the locks sit it are flat to the chassis. Relock and look for the bad drum.
What should I do when the Display says Service call 132:Error
After turning ON the
power or when cover
is closed, the sensor
detects that the unit is
missing.
1) Is an Error message displayed?
2) Is the LED head properly
mounted?
3) Does the Error take place
again?
Confirm that the lever is in
position.
Replace the toner feed unit.
Replace the ID units.
928 FATAL ERROR
Fuser Motor Lock Error The fuser is not operating properly
Check to confirm that the fuser
is in position.
Replace the fuser.
Replace the fuser motor.
