Ink absorber full
This mayclear the ink absorber problem.There is ink absorbers located at both ends of the printerwhere the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
SOURCE: My Canon MP180 printer/scanner/copier is
Follow this:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
SOURCE: ink absorber full
You need a new pad and you need to reset your code.
Codes are dependent on your model.
You can get more info here:
http://www.fixyourownprinter.com/forums/inkjet/32258
The ink absorber is a small tank that holds the waste ink your printer generates when it cleans its nozzles. Eventually that bottle will fill with ink and if not replaced will result in a terrible, sticky mess all inside your printer and the desk on which it sits.
I suggest contacting a local authorized repair facility for Canon or Customer Service for Canon and see if you can purchase a new absorber bottle without having to take the printer into the shop.
SOURCE: wast ink absorber full in canon mp1500 printer
http://www.ziddu.com/download/5724285/ResetCanonMP145.rar.html
download this link
SOURCE: Can I fix my full ink absorber myself? Canon iP1800
Only service centre can help you to replace the ABSORBER KIT.
