Yesterday I was drive my car, the road is going up,suddenly the engine was off,its looked like miss firing, after a few minutes I try to start the engine run over. The next day in the morning when I go to church,the car it doesn,t want to start and then I checked on the sparkplug wire no firing,No electric before coil and after,Please Mr.Mechanic Help me,Thank,'s GBU!
SOURCE: cars dies while running
Maybe it's the ASD relay? Also (sorry) the PCM! I hope this could help. Take care and best wishes to you.
SOURCE: 93 Jeep Grand Cherokee Won't start
The crankshaft position sensor was seriously problematic in those old jeeps. It's located towards the top of the bell housing slightly to the driver's side I think.
SOURCE: 1993 Jeep Grand Cherokee engine problem
If the crank sensor (reaR at bellhousing) is dirty, will not start, clean up and visually inspect
SOURCE: I have a 1994 Jeep Grand Cherokee Laredo 6 Cyl.
CHECK ASD RELAY THAT IS AUTOMATIC SHUTDOWN RELAY IN THE POWER DISTRIBUTION CENTER UNDER THE HOOD IN ENGINE COMPARTMENT.IF ASD RELAY GOOD PROBLEM COULD BE CAMSHAFT SENSOR IN THE DISTRIBUTOR.TO SAVE TIME AND MONEY HAVE JEEP SCANNED FOR CAMSHAFT SENSOR AND CRANKSHAFT SENSOR FAULTS.
Testimonial: "The solutions to my problem was very helpful so thank you so much for your advice!"
