20 Most Recent
Jeep 2002 Grand Cherokee Laredo 4WD Questions & Answers
What is the timing settings
If thats all you replaced, the timing hasn't changed by doing that. You may have a very loose timing chain and worn cam and crank gears that have allowed the timing to slip
P0138 location air fuel ratio
code p 0138 refers to heated oxygen sensor (HO2S) 2 bank 1--high voltage ===causes --wiring short to positive --HO2S--ECM
replace the sensor
Check battery light comes on when driving lights go dim 02 jeep grand cherokee
Most likely the alternator is failing to supply enough power to battery.
Check battery terminals and wires are clean and tight, check wiring to lights and alternator for signs of heat. Check voltage at battery with multimeter with engine running and a high idle. Voltage should be at least 13.5 volts with lights on or off.
