There is a syphon tube with a cover dome like a thimble. Lift it off, clean it and clear the syphon tube. Refit the cover.
Hi, where is the syphon tube?
In the drawer where you put the conditioner is a stand up tube with a domed cover. The cover acts as the siphon, and it usually gets really clogged up with solidifying conditioner. Pull the top off and clean it, clear the tube and, if you can, remove the complete drawer and clean it before refitting. If your domed top is missing, that will be why the siphon isn't happening.
SOURCE: my machine won't take the fabric conditioner. It
ok try removing the soap tray and cleaning. it works by filling to a certain level then allows to empty by way of Syphon effect, you can check this easy with a glass of water fill it as far can go does it drain away? It should , if it does then try with softner on wash should now be ok, providing The valve coils are okay..you can let me know.
SOURCE: Zanussi ZWD1470W fabric conditioner compartment won't drain
fabric conditioner is dispensed during rinse cycle, if it does not work then either, try pouring hot water into dispenser, as conditioner tends to get goopie when dry, thus may have clogged up
SOURCE: aquarius hotpoint wf541 wont pump the water out at
You need to clean the filter.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean the filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well
Hope this helps with your problem
SOURCE: Hotpoint aquarius wf100 has filled with water and
Following is my 'standard' word document, copied and pasted, which should assist you!
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
SOURCE: Fabric softener compartment won't drain. How can I
Remove the complete drawer. To do this you will have to do one of the following-
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this does not work, pull out the dispenser drawer far enough to be able to just see the softener tray, select the (final?) rinse and check that water is entering the tray. If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
