I want the driver (original DVD) of my Dell OptiPlex 330 Desktop Desktop Computer to have the possibility to format it.
SOURCE: i need dell optiplex 330 audio drivers for free
Please use the following links
For Windows XP
http://support.dell.com/support/downloads/download.aspx?c=us&cs=04&l=en&s=bsd&releaseid=R164899&SystemID=PLX_PNT_330&servicetag=&os=WW1&osl=en&deviceid=8639&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=0&libid=3&typeid=-1&dateid=-1&formatid=-1&fileid=221658
For Windows Vista
http://support.dell.com/support/downloads/download.aspx?c=us&cs=04&l=en&s=bsd&releaseid=R164900&SystemID=PLX_PNT_330&servicetag=&os=WLH&osl=en&deviceid=8639&devlib=0&typecnt=0&vercnt=2&catid=-1&impid=-1&formatcnt=0&libid=3&typeid=-1&dateid=-1&formatid=-1&fileid=350245
Click Download button.
Another window will open. Click on the Download button under download
via web browser.
SOURCE: Dell (ie optiplex 330) would not boot with the orange light on
Do you have a lot of accessories plugged in? They may have overloaded the power supply and if this is the case you will need to buy new power supplies. If this is not the problem, check to make sure that the computers have plenty of ventilation in the back. If they don't, they may have overheated and melted quite a few different components.
SOURCE: no sound on my dell optiplex 330
Unless you have headphones, you need speakers, preferrably amplified speakers.
Another way the address the issue is to use a cable to connect your computer to your home stereo if it has an auxilery input (aux/cd/tape input) then all you need is a cable with two male RCA plugs on one end and an 1/8 inch stereo plug on the other end.
The 1/8th inch plug goes into your computers' sound "out" and the rca's go into the aux/cd/dvd "IN" on the stereo.
this cable can be purchased for under 10 dollars at walmart, though amplied speakers wont be much more expensive.
Hope this helps you decide which direction to go..
Regards..
SOURCE: in my dell desktop optiplex 330 hard disk is
Is it a BIOS password or a HDD password? If it's sewt in BIOS, you could try to reset the BIOS to factory default (which should remove any BIOS passwords) If however it is a HDD password, it is a bit different.. you may need to restore your sytem (low level, high level formats, then reload your OS sorry but you likely lose all your data..What OS do you use? there are programs that can possibly give you a boot cd depending on whether your system is fat32 or NT.. NT is more complicated because fat32 will not read NT BUT NT will read fat32.. IF you have the ability to restore your OS then first try to do a complete restore with backup.. that way you may be able to save most of your datafiles.. if you have never accessesd the pc then just try a destructive system restore (will low-level, then high-level format the HDD and reinstall your software without any SW passwords..
First thing I would try is to get into the BIOS and unset any passwords there.. If you need more help you can try to contact me [email protected] with more information
