20 Most Recent
Dell OptiPlex GX270 PC Desktop Questions & Answers
Strike f1 retry boot f2
Question posted in 2014, almost 5 years back, laptop by this time seems to be abandoned or scrapped? and if still searching only solution is to change the Hard Disk Drive
Gx270 Willnot boot in to winodws xp
sounds luike you might have had a virise and its wiped somonthing it souldint have out you can save your things in safe mode and re do the os (reinstall windows ) if you recantly conected hardware to then unistall and disonect it then retry it
How to replace battery in GX 270
Look on the Dell web site for the GX270 'service manual' - if no luck, then I suggest you post this question to the DELL WEB SITE HELP forums ..
When booting my dell optiplex dimension 270 i get an alert message of checkpoint [krst]
Try running the Check Disk Utility.To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /rCheck disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine. If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
I need to restore my computer without disc, what should I write in command prompt?
To access the System Restore Gui from command prompt you will need to type in rstrui.exe
OR
%Windir%\System32\rstrui.exe
Other Thoughts
If you are experiencing Boot issues you will need to install a boot manager. If your system is missing a file or a file is broken, you may need to replace that file with a working version that's compatible with your OS Version.
Attemped to find a Video Controller Friver(VGA
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R79733&SystemID=PLX_PNT_CEL_GX270&servicetag=&os=WW1&osl=en&deviceid=6294&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=1&libid=6&fileid=104486
There is a couple other choices to choose from, but this should get the job done. Just copy and paste the link above in your browser window. Download the driver and follow instructions.
Dell GX270 has D amber light
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard.
Remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
