20 Most Recent Dell OPTIPLEX 960 MT Desktop Computer (Intel Core 2 Duo E8400 250GB2GB) (BO5SC306) Questions & Answers
2answers
My optiplex 960 does not turn on
bad capacitors were the bad boys , i have replaced the starting capacitor valued 1000uF 10v just across the switching IC and it worked
12/20/2016 1:20:14 PM • Dell OPTIPLEX... • Answered on Dec 20, 2016
Error light code 3 & 4 in front panels
Hi Carlos, error code 3 & 4 is caused by faulty RAM (Memory modules) installed in the PC. You could try the following to resolve the issue: 1. Open up the computer cover 2. Locate the memory module(s) 3. Remove them memory module(s) 4. Use a can of compressed air or spray contact cleaner onto the center of the DIMM connectors to clean all the contacts. Do NOT use a normal brush to clear dust away. Wait for 5minutes for the contact cleaner to dry. 5. Reseat the memory module(s) 6. Turn on the computer and check if codes 3 & 4 still light up. If it does not, it should boot into the Operating System. 7. If codes 3 & 4 continues to light up, you will need to run a memory diagnostic test to determine which of the memory module is faulty.
9/7/2016 2:30:26 AM • Dell OPTIPLEX... • Answered on Sep 07, 2016
Why does it keep rebooting?
OS is corrupt and needs to either be repaired or reinstalled.
10/22/2015 9:56:51 PM • Dell OPTIPLEX... • Answered on Oct 22, 2015
ALL I KNOW IS ITS A DELL OPTIPLEX 960 AND I TRIED TO DO A REBOOT BY HITTING F2 AND THEN HOLDING ALT AND F AT THE SAME TIME.
Hi Tiffany, it sounds like there has been some sort of corruption of the files on the hard disk. You should see about booting from the Windows installation CD / DVD and copying all the files that are of importance to you (documents, photos, music, etc.) on to an external hard drive connected to the USB port or installed as a slave drive internally. Once you have saved all the files you need, shut off the PC and disconnect / remove the drive with your files. Then reinstall Windows again. Once done, shut off the PC and reconnect the drive with your files and copy them back to the hard drive and you should be good to go unless he drive is beginning to fail - in which case purchasing a new hard drive would be a good idea.
8/10/2015 9:30:54 PM • Dell OPTIPLEX... • Answered on Aug 10, 2015
DMA page register read/write failure
According to Dell you will need to run their diagnostic utility to find out what is really causing this error code http://mss.net/Links/DellDocs/OptiGX260/UserGuide/advtshoo.htm#1163831 read the part about how to start dell diagnostic
2/27/2015 12:50:46 AM • Dell OPTIPLEX... • Answered on Feb 27, 2015
Trying to find ssid password on wired desktop
Best way is to contact your service provider. I have Verizon and they're a big help for that. Hope this helps.
2/21/2015 9:24:17 PM • Dell OPTIPLEX... • Answered on Feb 21, 2015
My Optiplex 960 flashes amber 3 light when powering on.
Hey, have you ever thought that you ANSWERED YOUR OWN question? If you press the power supply TEST button, then it powers up fully? It's NOT the button.......So...what else could it BE then Mitch?
5/1/2014 2:16:38 PM • Dell OPTIPLEX... • Answered on May 01, 2014
I have dell 960 switch it on but light turns to orange
Could be several things. 1. could be the power supply 2. inspect the motherboard for bad caps. If the above is OK. Try removing and reseating the CPU, Memory and CMOS battery.
4/16/2014 4:16:21 AM • Dell OPTIPLEX... • Answered on Apr 16, 2014
0answers
Dionex 3100 VWD lamp ignition fails lamphouse
Probably needs a new power supply or power switch.
9/22/2013 6:42:07 AM • Dell OPTIPLEX... • Answered on Sep 22, 2013
How do i get the computer to start up when all it does is flash the Dell logo
Larry provides great information. Larry Ng Apr 30, 2022 good news the not told at all PC screen is not dead. a major fact but lacks all evidence like: 1, No PC told no OS told xp to w11 2: fans spin? all do, psu ,cpu and gpu card if fan. 3: Optiplex is a desktop 29 years of models made wow. 4: you mean Dell Splash logo. yes, and then it does the post bar, if post bar stalls that means hardware gross errors. sadly no PC model told of vast versions. wow. just wow hopeless that.? but is par here, and vast wrong answers just for that fact alone.even mine. i have many optiplex PC here old and new and my fav is 9020MT or smaller my oldest is 380(in storage) is your coin cell dead. (if yes can NOT be ignored) my dells all have F12 diagnostics, power on and hammer F12,, pick diag eSPA and run it older PCs dell if the HDD is dead the F12 diag is dead. due to being located there back long ago. my dells have a BIOS log page, go to BIOS the click tab, LOG read the logs. see what fails. (coin cell RTC sure)_ easy no?\ but why on earth post lacking the model number making any useful simple help 10 pages long for 29years of models. 1993 is the first OptiPlex, seen here. https://en.wikipedia.org/wiki/Dell_OptiP... nobody can guess and no era is the same. evolution max. ..
4/30/2022 6:05:08 PM • Dell OptiPlex... • Answered on Apr 30, 2022
Dell OptiPlex 3020 Desktop computer startup problem?
What is the exact error that you are getting? Do you get any blue screens? Have you installed any software recently or made any changes? I can only suggest checking the power cables and trying to use a different cable or spare if you have any for now.
7/13/2021 12:42:34 PM • Dell OptiPlex... • Answered on Jul 13, 2021
2answers
I'm trying to connect to google and it say's " your connection is not private"
Sounds like your on Google Chrome, this has started popping up since the last update and only on secure webpages at random, try running Windows Update and make sure it's up to date, it check the root certificates which should come with the windows updates.
10/22/2019 7:03:49 AM • Dell OptiPlex... • Answered on Oct 22, 2019
Dell OPTIPLEX 960 MT Desktop Computer (Intel Core 2 Duo E8400 250GB2GB) (BO5SC306) Logo
16 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
OptiPlex Dell
  • OptiPlex Dell
Most Popular Question
optiplex 960 not turn
  • Computers & Internet
