i have a router where it shares tha phone fixed line and the internet, to use my fax funtion i conncted the officejet to the router in the jack where the phone fixed line wire should always be, and i loaded the original and pressed the fax no. and started the transaction, but after it gives me the faxing tone, it gives me a message that sending fax has failed, i repeated that for more than million times, but in vain, althought i used to do the same before and it was sucssesful, plz help its very urgent.
SOURCE: Fax rings but will not pick up or give fax tone
hmmm..that's a fax settings issue on the front panel...you may new drivers for that hp.
get them here
SOURCE: HP Officejet 5610 Fax Failure
you may need to reinstall the driver set, which can get corrupted with power glitches.
www.hp.com for fresh drivers
SOURCE: FAx Line will not pick up or send faxes on HP 6110 All in One Officejet
it seems like you have lots of services on your line. here are the things that i want you to follow to somehow resolve the issue.
1. Press the setup button on your printer, then use the arrow down button to scroll down and go to ADVANCE FAX SETUP.
2. Press okay on Advance fax setup, then it will give you options.
3. The first option is DISTINCTIVE RINGS, press okay on that.
4. It will give you first option "DISTINCTIVE RING", scroll down and look for "answer on double rings" then press okay. then try letting someone send you a fax.
Note: make sure that your answering machine is using your home telephone line so that it wont affect the faxing functionality.
1. if the issue still not resolve, try to press setup, then go to TOOLS.
2. press okay on TOOLS and it will give you options, scroll down using the arrow down button and look for RUN FAX TEST.
3. Check the result of the test if everything passed!
Let me know if the issue still not resolve so that i can go ahead and give you additional steps.
thank you so much.
adonscott
SOURCE: Fax will not send or receive
Hi
You need to contact comcast for this issue and get a seperate phone line to which u need to plug in the allinone. This issue may exist most of the Comcast customers.
thx
SOURCE: set up fax and dsl using one phone line
You can buy a splitter to put on your line so you can run both devices. They sell them at the dollar tree big lots and everywhere else usually, and range from .59 to $2. as far as another DSL filter ask a friend neighbor or co-worker if they have or had dsl and have an extra filter. If not then you can pick them up for a couple of bucks at radio shack
