Sewing Machines Logo
Pam Gaines Posted on Feb 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Janome 10000 is coming up with an error that asks 1. is there some thing jammed in the machine 2. is the needle bent 3. is the material too thick
Then I noticed the hand wheel was very tight. How can I fix this. There is no broken needle, thread, jam or anything. I have taken it apart and cleaned thoroughly0 The hand wheel still wont turn, so I can't us the machine. Any ideas?
Debbi's Sewing Machine Repair
Level 3:
  • Janome Master 7,365 Answers
  • Posted on Feb 28, 2012
Janome Master
Level 3:
Answers
7365
Questions
Helped
1744481
Points
19451
It could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be serviced
3 Related Answers
bargainbox
Hassy
  • 1388 Answers
  • Posted on Mar 14, 2008
SOURCE: Janome 10001
This is a protection mechanism of the machine when it believes there is too much strain on the motor.
Check the hook race/bobbin area...for lint or thread jam....also check the couterweighted cam that drives the needle up & down, as ofter thread will catch and be wound around the shaft near the take up lever.....open the door on the Left (Face Plate) and where the shaft comes through the body is where to look, move the handwheel slowly and watch for threads....remove them gently by unwinding, be patient as they may be well jammed.........DO NOT pull and break them !!
If you are convinced there is nothing jammed & if all appears clear, there are 2 possible scenarios, and I am afraid you are not likely to be too pleased by either of them.........please don't shoot the messenger.
The DC motor is failing, or
The "A" board has problems.
Janome have a 5 year warantee on the Circuit board and will replace it if it fails within this period.
This is a complex and valuable machine and may need the services of a well qualified Janome Trained Service Technician, not just any old hack repairman.
Protect your investment.
Best Wishes and hopes it's just the thread jam.
Anonymous
  • 323 Answers
  • Posted on May 19, 2008
SOURCE: bobbin thread wont pick up
Be sure needle is inserted correctly with the flat side in the proper position. Rethread the machine and try again. If it still won't work you have a timing problem which requires a technician or a good mechanic.
sewman7
drifterK
Catalin Turcu
  • 4924 Answers
  • Posted on Aug 22, 2010
SOURCE: My Janome 10000 is coming
the error is cause by the sensor that detected it in the first place ..what you should do is reset it to the factory setting s...Look in the main menu for reset to factory settings or defaults..and engage them ..
LO comes up on my 3160 QDC Janome sewing machine.
Check for a thread jam under the needle plate. Wait for the machine to cool after the overload. Your material may be too thick or heavy for the machine.
I hope this helps.
3answers
Janome 10000
so..it only happens in your house? anything odd about the power coming to your machine? have you tried it on another outlet? that might explain why the dealer can't see the problem...
My janome me 10000 keeps giving me a warning message that says is fabric to thick is needle bent is something stuck in machine. I just had a new circuit board put in. Why is this doing this
That is the wierdest error message I've ever seen on a sewing machine. Did you try a brand new needle? Are you sewing thick fabric (does the message appear when sewing light-weight fabric? Remove the bobbin case from the machine and check for thread wrapped somewhere. If you are not able to find an answer on your own, then it's probably best to take it for service.
Janome MC10000 Warning Machine Wont Sew
Janome 10000 - I get a warning message and the machine quits. I've had it to a repair person 4 times
If you've had it in for repair four times, then the technician is not doing a good job. Take it back and insist it be fixed... talk to the manager and relay your dissatisfaction with the service. OR ask for a refund and take it to a reliable Janome technician.
You don't mention the error message, so it is very difficult to try to assist.
My Janome 10000 seems to have jammed the fly wheel won;t turn, There is nothing stuck in machine, needle is not bent
yes, it is possible. or a part inside the machine could be broken
it would be a good idea to have the machine checked.
10000 janome jamming fly wheel won't turn
I would replace the needle anyway. It's hard to tell if one is bent or not.
Remove your feed dog/needle plate and the bobbin cover. Take out your bobbin and bobbin carrier.
Get out a magnifying glass and really examine. Look for thread ends in between moving parts.
Also check the thread pathways. Especially where the take up lever is hidden. I've heard of some ladies finding threads snarled up in that area which caused problems like this.
Good luck. If all else fails take it in for repair.
3helpful
2answers
Thread is knotting up on bottom of fabric causing it to stop
1.check the needle & see if it's bent--if so replace
2.lay the needle on a flat surface & roll the needle over if it doesn't roll true replace
3.check for blunt needle-if needle makes a popping sound when needle penetrates fabric
4.needle is not all way up in holder
on my mechanical sewing machine sometimes the threads come off the take up lever, that causes the thread to bunch up under something I'm working on
also check thread in bobbin
2answers
Janome 10001
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
