20 Most Recent
Janome 4623 Mechanical Sewing Machine Questions & Answers
Thread is knotting up on bottom of fabric causing it to stop
1.check the needle & see if it's bent--if so replace
2.lay the needle on a flat surface & roll the needle over if it doesn't roll true replace
3.check for blunt needle-if needle makes a popping sound when needle penetrates fabric
4.needle is not all way up in holder
on my mechanical sewing machine sometimes the threads come off the take up lever, that causes the thread to bunch up under something I'm working on
also check thread in bobbin
Electrical problem?
Neither the needle up/down or the LED for the stitch selector will work if the bobbin winding pin/holder is pushed to the right (meaning pushed into the winding position). If you accidentally left the winding pin/holder pushed over, you will lose the functions of both the LEAD and the needle up/down button! (Neither of these functions can work while in bobbin winding mode!)
I cant figure out how to fill the bobbin
it's possible that your thread guide may be off some & needs to be adjustedor the bobbin isn't being pushed down far enough on the spindle to click into place to hold good
Janome 4623 le bottom tension loose
adjust the top tension up one number at a time & then sew a sample, if it's still loose then increase one more number until you get the desired stitch.
LED that illuminates the stitch selection bar quit
Check your bobbin spindle. If engaged (pushed toward the right) LED will not light. When the clutch knob is pulled out, when you wind a bobbin, the up & down needle will not move. So you must push the clutch knob in again to let the up & down needle go up and down. The clutch knob on my machine is in the large hand wheel upper right side of my machine.
The LED light won't show up
Check your bobbin winder spindle. It may be engaged. (pushed to the right). Push it to the left, if it's pushed to the right and the LED will go on.
I have a newish 2nd
Have you got the thread through the take up lever correctly? If its not threaded this will cause the needle thread to be pulled backwards. Just recheck all the threading paths from spool to needle have been done correctly.
I have a Janome 4623
Oil any movin g part that you can get to and only a couple of drops of oil before you use it.
My fabric wasn't moving so
Hello
Turn off the power. Remove the accessory compartment located in front of the machine, if applicable.
Open the hook cover that shields the bobbin area. Please note that you do not need to remove the bobbin case.
Locate the drop feed lever near the bobbin case. Some machines have the lever towards the back of the free arm. Press down on the lever and then move it to the next notch or position. The raised metal feed dogs should be visible through the openings on the needle plate. You may need to rotate the big balance wheel one rotation to engage the mechanism on some machine models. The metal teeth will then spring up.
Close the hook cover. Insert the accessory compartment, if applicable.
Turn on the power. Try test stitching a piece of fabric. The raised feed dogs should help guide the fabric under the presser foot.
