Sony VAIO PCG-K27 Notebook Logo
Posted on Feb 21, 2012
Need wpa key to connect to network
Netgear network / security-enabled network (wpa) I need a wpa key
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Feb 21, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
217
Points
9
If this is your home computer, you are probably going to have to reset the router if it is yours
here is a guide
http://support.netgear.com/app/answers/detail/a_id/9665/~/reset-and-restore-the-netgear-device-to-factory-default-settings
Wpa key ps3 netgear extender
Reset your wireless router. Unplug and plug back in.
tip
Secure your Wireless Router - General Guide
How do I secure my wireless router? A general guide
To set up wireless router security, there are four main steps, which are the same for most routers. These are:
1) Login to your router, using a wired connection
2) Change the router login password
3) Change the network name (SSID)
4) Enable WPA encryption.
This is a very general guide, which will use the Netgear DG834G wireless router as an example. As every router is different, you will need your user manual to get the most out of this tip. (If you need help with finding a manual, see ‘How To Find a Router Manual’).
Here are the details:
1) Login to your router, using a wired (Ethernet) connection.
Make sure you have a cabled connection to your router. Then open a web browser, and type the router’s IP address into the address bar. For example, this is http://192.168.0.1 for the Netgear DG834G (Note, there is no ‘www’).
Enter username and password at the prompt.
Netgear DG834G: the defaults are username: admin and password: password (or, for UK Sky users - username: admin and password: sky). Other routers – common usernames are admin or blank: common passwords are admin, password, 1234, or blank.
If you log in successfully, you should then see the router configuration screen.
2) Change the router login password.
To change the router password, find a menu option such as Setup, Tools, Administration, Basic Settings, Management, or Utilities. On the Netgear DG834G – this option is under Maintenance > Set Password.
Set and confirm a new login password. Click ‘Save/Apply’ when finished.
Tip: Write the router login password on a label, and stick it to the router.
3) Change the SSID (network name):
The SSID or Network Name is the name you see when you are looking for an ‘available wireless network’.
To access this setting, find a menu option such as Wireless, Wireless Security, Security, or perhaps Advanced Settings. For the Netgear DG834: the Network Name/ SSID option is under Setup > Wireless Settings.
Change the SSID from the default, to anything you like. It is case sensitive, and you can use up to 32 letters – but do not use something that could identify you, or your location. Click ‘Save’ or ‘Apply’ when finished.
Find the Wireless Security or Wireless Encryption Options section - often in the same section as the SSID (eg for Netgear – it’s still in Wireless Settings).
You may have a number of encryption options. Select WPA-PSK or WPA2-PSK (good choices to start with).
You then need to enter a network key. The box to enter this may be labelled Network Key: it may also be labelled WPA-PSK, WPA Shared Key, PSK, Security key, Passphrase, Pre-shared key, Authentication key . On the Netgear DG834Gv3 it is labelled ‘Network Key’.
The network key should be a long password, or passphrase, between 8 and 63 letters/numbers long. This can be any series of letters/ numbers, or you can use a phrase with numbers - eg, 451ThisisGooDFunforgEeks7899. It is case sensitive. (If you think your connection is likely to be hacked, pick a very strong network key.)
Note down your network key carefully. You will need this to connect wirelessly. Click ‘Apply/Save’ when finished.
That's it - you have done enough to secure your network, and can close the screen.
There are further security options to enable if you wish, but these three are the most important.
When you next connect wirelessly, you should see your wireless router with its new name in the 'available wireless networks'. When you attempt to connect, you are asked for the network key you set in Step 4. If all goes well, you can then save this and will connect automatically in future.
If you get stuck with any of this, consult your manual, or post on Fixya. Good luck with securing your router.
A word about WPS: WPS is a shortcut method to help you implement security on a wireless router. Consult your user manual if your router is WPS enabled, and you prefer to use WPS.
All information is offered as is, without warranty. If you choose to use it, it is entirely at your own risk. Thanks to all Fixya contributors who helped with this tip. Advice and links current at time of writing. Written by ‘eecom’, Jan 2009.
on Jan 10, 2009 • NetGear DG834G Router
3answers
I dunno ow to secure my connection with my edimax router
You can read more about WEP and WPA in the following links:
This article explains how to configure WEP/WPA-PSK/Access list on NETGEAR Wireless router (also applicable to access points).
Note:
  • You can configure WEP or WPA. But you cannot enable both at the same time.
  • You can configure Access list and also enable WEP or WPA for additional security.
  • After you enable wireless security features on the router (or access point), you must configure your wireless clients (wireless computers) with matching settings. Your wireless clients will not be able to connect unless you configure matching settings.
  • Its recommended you enable these wireless security settings from a computer wired to the router (or access point).
Configuring WEP:
  1. Connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1 (by default, refer to your product documentation ti determine the default IP address.) in the address bar and press Enter.
    The Login window will be prompting for a Username and Password. The default Username is admin and the default Password is password
  4. Under Security Options, Select WEP (Wired Equivalent Privacy)
  5. Select Authentication type as Automatic and Encryption Strength as 64-bit (or 128-bit) - You must later configure your wireless computers with the same setting.
  6. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength) and Apply the settings. Please note down these values - You must later configure your wireless computers with the same setting.
I need to secure my router. I had payed to have it set up when I was getting my computer fixed only to find out that my son could log on with out a password. How can I fix this.
************DETAILS************
Wireless security via MAC address
I would enable WPA encryption and keep the MAC security on. Even though no other computers can connect due to the MAC security, without the encryption your network still looks wide open and it will tempt people to connect. At least if they see there is some sort of encryption on they will not even bother with trying to connect to it.
NETGEAR WGR614v7 Network Security key
Hi, you need to connect to the routers admin pages to configure the wireless settings and security. Check out this page:-
http://kbserver.netgear.com/kb_web_files/n101676.asp
When you get to step 6, click the WPA-PSK security setting and it will give you a box to type in a password of your choice, make it memorable but difficult to guess, so a mixture of numbers and letters. I think its a min of 8 characters.
Hope this helps..
I cant connect thru my netgear router model wgr614v7
If you hook your PC directly to the router using an Ethernet cable you don't need the key. You can log into the router and change the WEP Key to anything you want, but u have to be directly connected to the router not going through the wireless.
Securing our wireless connection
Hi … perhaps I can help..
There may be more than one way to set to set up security on this router. However, most routers accept manual configuration. There are four main steps to this:
1)Login to your router
2)Change the router password
3)Change the SSID, or network name
4)Enable WPA encryption.
Here the details (based on the Netgear Rangemax manual - if this is not your model, please check back):
Important note: use a wired (ethernet) connection to the router to set up wireless security.
1) Login to your router.
You have probably done this already, but here it is again for clarity. Type the router address in the address bar of a web browser. The default for this model is http://192.168.1.1 or you could try www.routerlogin.com (or .net)
You are prompted for the username and password. If you have not changed the password, enter username: admin and password: password
This should bring up the configuration screen/user interface.
Under Maintenance in the left hand menu, go to Set Password. Set and confirm a new password. Click ‘Apply’ when finished.
Tip: write this on a label and stick it to the router.
Under 'Setup', go to Wireless Settings. You should see the Wireless Network Name,or SSID, at the top. Change this from the default, NETGEAR, to anything you like – as long as you can remember it. It is case sensitive, and you can use up to 32 letters – but don’t use something that could identify you, or your location. Click ‘Apply’ when finished.
4) Enable encryption
Still in the Wireless Settings menu option, you should see the Wireless Security Options section. You have a number of options for encryption. Select WPA-PSK: though strictly speaking, the correct option depends on your wireless adapter. However, this is a good choice to start with.
Under Passphrase or WPA Key you should enter a long password, or passphrase, between 8 and 63 letters/numbers long. This can be any series of letters/ numbers, or you can use a phrase with numbers ( eg - 456HapPY2009toyou8892). It is case sensitive.
Note down the passphrase, or network key, carefully. You will need this to connect wirelessly. (The network key may also be called a WPA shared key, PSK, pre-shared key, authentication key, WPA key, WPA-PSK, security key). Click ‘Apply’ when finished.
That's it, you have done enough to secure your network, and can close the screen.
When you next connect wirelessly, you'll see the router with its new name in your 'available wireless networks'. When you attempt to connect, you are asked for the network key you set in Step 4. If all goes well, you can then save this and will connect automatically in future.
Hope this helps you. Please come back to Fixya if this doesn't work or if you need help with any of it.
Securing wireless connection
Hi again, glad to help if I can.
Securing the wireless signal will temporarily disconnect the PS3, which will need to be set up with the new security details in order to connect again.
There are four steps, which are the same for most routers:
2) Change the router login password 3) Change the network name (SSID)
3) Enable WPA encryption
1) Login to your router, using a wired connection.
On your desktop PC, open a web browser, as if to view a web page. Type the router address into the address bar, which is http://192.168.0.1 for this model. You can also use www.routerlogin.com for Netgear.
You should then see a popup box, prompting you for a username and password. If these have not been changed, they will be the defaults of username: admin and password: password
If you log in successfully, you should then see the Netgear configuration screen.
To set a new password, go to the left hand menu: under ‘Maintenance’ click ‘Set Password’. Set and confirm a new password. Click ‘Apply’ when finished.
Make sure this is not easy to guess, otherwise someone could login to your router and view/change your settings. (Tip: write the password on a label and stick it on the router, or keep it somewhere safe. )
3) Change the SSID (router name):
Go to Setup > Wireless Settings. Under ‘Wireless Network’ you should see an option marked ‘Name’ or SSID. Change this from the default, ‘netgear’, to anything you like, that you can remember. You will need this when setting up the PS3 again. It is case sensitive, and you can use up to 32 letters –but do not use something that could identify you, or your location.
Still in the 'Wireless Settings' menu option, you should see the ‘Security Options’ section. You have a number of options, but I would pick WPA-PSK, which is very secure and good for most equipment.
Under ‘WPA-PSK Security Encryption’ you need to enter a network key. This is a long password, or passphrase, between 8 and 63 letters/numbers long. This can be any series of letters/ numbers, or you can use a phrase with numbers ( eg - 456HappynEWYeartoyou8899). It is case sensitive.
Note down the network key carefully. You will need this to connect wirelessly. (The network key may also be called the WPA shared key, PSK, pre-shared key, passphrase, or authentication key.) Click ‘Apply’ when finished.
When you next connect wirelessly, or go to configure the PS3, a scan should bring up the router with its new name in the 'available wireless networks'. When you attempt to connect, you are asked for the network key you set in Step 4. If all goes well, you can then save this and will connect automatically in future.
Hope this helps you. Please come back to Fixya if it doesn't, or if you need help with any of it. Good luck!
I cart my IBM Thinkpad Lenova T60 back and forth to/from work and work from home 1/2 the time. Computer stays on most of the time and connects via docking station at work and wireless Netgear RangeMax at...
change the wireless security to WEP or WPA-PSK (TKIP)
A. Checking the Wireless Settings of the Router
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it doesn't take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you can't remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on the Wireless Settings under Setup and take note of the SSID.
5. You may also change the wireless channel here. We suggest channels 1, 6 and 11.
6. At the bottom of the page, look for the Security Options. If in case that the security is set to WEP or WPA-PSK, we have to enter the same wireless security on all wireless PCs. To make sure of the key, we can try modifying the security. Please refer to the following:
For WEP: Select Key 1 and enter 10 hexadecimal digits (0-9 and A-F) on the empty box beside it. Then, click on Apply.
For WPA-PSK: Enter an alphanumeric key (minimum of 8 characters) on the Passphrase box and click on Apply.
Note: The Key and Passphrase are case-sensitive.
7. On the left pane, please scroll down and click on Wireless Settings under Advanced. Please make sure that the boxes for Enable Wireless Router Radio and Enable SSID Broadcast are checked.
8. Click on the Setup Access List button and uncheck the box Turn Access Control On.
9. Click the Apply button.
B. Connecting to the Wireless Network
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
For Windows Vista:
1. Click Start then select Connect To.
2. Connect to a network window will show up.
3. Select your wireless network and click Connect.
4. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
