20 Most Recent
NetGear DG834G Router Questions & Answers
Netgear router dg834gt
Have look in the router settings for the actual internet connection speeds, as these are a more true reading than the speed check as the speeds can vary at different times of the day and 2 or 3 speed checks can bring different results.
your actual connection speed that is showing in the routers settings is the connection you are getting from your ISP.
If you are with BT they usually recommend using their latest routers, why i'm not sure, as the only thing i have noted is that the MTU is set at 1500 (Maximum Transmition Units)and in other routers the MTU is automatically set at 1493, so look for the MTU setting and up it if necassary, but not above 1500, also double check all the settings, even put the bt router back in and see if speeds improve, if, you know the BT router is set up purposly for faster connection speeds.
Also try checking your speed at a speed test site at a quieter time of day, you will also see different speed check sites give you different speed results.
Netgear router
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet ?i? LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Connecting Ipod touch 8(GB) to Wi-fi
BEWARE SPAM NUMBER +1-800-532-4187 BELOW
After fighting with this for the last couple of hours I have my ipod touch working with the netgear DG834G(v3) router. The fix is a bit odd and I am not entirely sure why it works but I thought I would share and hopefully it might help you out …
First I think that the WEP encryption simply does not work between these two devices and causes some very strange behaviour – the WEP 'authentication type' setting I had on the 'wireless settings' page was set to 'shared key' – I flicked this to 'automatic' & strength to ‘128 bit’ - hit apply and finally I found I was able to connect without an error message (after inputting the correct WEP key). Unfortunately the DHCP did not work correctly after this and I kept receiving IP addresses in the range of 169.254.x.x (an internal default) rather than my networks expected 192.168.0.x range. The Ipod touch couldn’t find any DNS servers or connect to the internet.
To get round this I set the router ‘security options’ to use WPA instead (WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)) instead of WEP. Set the new WPA password at the bottom of the wireless settings page - again hit apply - and configured the ipod to use the new password and WPA PSK instead of WEP. This worked fine – although it does mean I have to change the settings on all my other wireless devices around the house!
The weird thing is that although the router isn’t using WEP encryption changing the 'authentication type' setting back to ‘shared key’ in the WEP menu breaks the WPA connection again – very odd? I blame netgear and their obviously crazy wep code :)
Netgear wpn824v2 can't login to router, can't reset defaults. BEWARE SPAM NUMBER +1-800-532-4187 BELOW
The router username is always admin
The default password is password or (for older routers) 1234
Try the default username and password before resetting the router to the factory defaults.
When a router resets, it goes back to the state when it was new — all information that was entered by hand is lost! Examples are critical things you need to get online, such as ISP username, ISP password, IP addresses, security keys, and ports and services that were opened. It all needs to be re-entered.
So, have your ISP information before resetting the router.
Naturally, if you moved to a new city, or if you bought a used router, the old information in the router may not be of use to you. Contact your ISP if you can't connect any computer directly to the Internet. Then, if there is a connection problem when the router is added, see No Internet Access Through the Router
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
Press the reset button on the back until the test light blinks.
This takes about 10 seconds.
(To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
Release the button.
Wait for the router to reboot.
Log in with the default password.
If the router was not cleared, try these additional steps AFTER the router has finished rebooting.
Unplug the router's power.
Press and hold the reset button.
While the button is held down, reconnect router's power.
Continue to hold the reset button for 20 seconds after reconnecting the power.
I cannot access the netgear settings.
to access the router you will need to open up your web browser and type in 192.168.0.1,it will then ask you for a user name and password ,the user name is admin,the password is password,that will get into the netgear utility for the router,that info can also be found on the bottom of router,if that doesnt work then you will have to reset the router to the default settings by holding in the reset button for about ten seconds located on the back ,you will have to use something that is small enough to depress it,you have to reset it while it is on,if you got it used then you should reset it anyway so that you can configure it according to your situation,ok have fun and good luck,you can get detailed info from netgears website.
I need to reset or find my origional password.
If you have changed the default password, you need to reset the router to the factory settings to get in with the default user and password (user admin and password as password, or if that doesn't work try 1234 - these are the default password for NetGear routers). Note that you will lose the ISP settings and wireless settings when you reset the router.
Here's a video on how to reset the router to the factory default settings: http://kbserver.netgear.com/media/flash/training/Troubleshooting/NG_WGR614V9Router_TS_LostPassword.html
How to do a complete reset of netgear wpn824 v2
Well it seems that you have uploaded the firmware on the router using wireless connection. The firmware on the router has corrupted and now does not seem to be recoverable.
Dude if it is under warranty then get it replaced. To log a complaint with NETGEAR go to this site:
http://my.netgear.com
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Can I have a wired and wireless connection from the same router?
Hello..the quick answer is yes, this router allows wired and wireless connections at the same time, and it is easy to connect wirelessly (in theory...).
The PS3 will need to be configured to connect to your router, though. There is a guide to achieving this here:
If the wireless signal on the router has been secured, the settings used will be needed to set up the PS3.
If not, you may wish to secure the wireless connection, which is not too difficult - just a few steps, which I or someone else can help with if you wish.
Hope this helps, but please come back to Fixya if anything is not clear or you need further information.
Have installed a netgear ps121v2 server. Will work
following steps can fix your Issue
1. Please confirm you are able to print by connecting the printer to the Vista computer directly.
2. Click Start - select Control Panel then switch it to Classic View from left side.
3. Double click on Printers & Click on 'Add a Printer'.
4. Select 'Add a local printer' & Click next.
5. Select 'Create a new port'.
6. Select 'Standard TCP/IP Port' as 'Type of port' then click 'Next'
7. Enter the IP Address of the Print Server in the 'Hostname or IP address' field.
8. Uncheck 'Query the printer and automatically select the driver to use' & Cilck next.
9. Select 'Custom' then Click on 'Settings' on the next dialogue box.
10. On the next dialogue box, select 'LPR' as the 'Protocol'.
11. Under the LPR Settings put in any name for the 'Queue Name'.
12. Check 'LPR Byte Counting Enabled' then click on OK and next.
13. Select the Manufacturer and the Model Number of the printer. If it is not available then click on 'Have Disk'. Click 'Next'.
14. Check 'Set as the default printer' and click next.
15. Try to print test page, it'll print.
regards,
prakash
I need to know what my password is
If you lost your password you will need to reset into factory settings. There will be a pin hole near power wire use a tooth pick or paper clip or something of thAt size and push in and hold for 30 seconds. You will have to reset all settings. Or if you never set the password try admin as user name and password as password. That is usually the factory set info
