Patton PUH680-U Utility Heater Logo
A
Anonymous Posted on Feb 01, 2012
What does switch #1 on the patton puh682 mean
2 Related Answers
Anonymous
  • Posted on Dec 28, 2008
SOURCE: I purchased a Patton model PUH682 in October
Thanks for your getting back to me. I was finally able to get through to someone in customer service at Walmart, they informed me that this model was recalled by the manufactuer. Thanks
Anonymous
  • Posted on Jan 07, 2010
Does anyone have any info on whether the PUH682 was actually recalled?
1helpful
Can someone explain how to identify overheating sensor for Patton PUH682 1500 Watts Workman or similar utility heater and also how to adjust, bypass or replace it?
replace heater, or if wish the opportunity to start a fire, bypass high limit.. However there are no repair parts, Go the safe route and replace it, looked and they are eBay from $25.00
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Where can I find replacement thermostat/s for the PUH682 electric heater/s.
I would think the contacts are burning out on the line voltage thermostats. The contact areas have been reduced over the years so they last just past the warranty period. If it were mine, I'd locate a line voltage baseboard heater thermostat and adapt the control to operate the heater elements. Much higher amp rating and built more substantially.
2answers
Starts then shuts off
My Mighty Heater 1500 will run for 15sec then shuts off then repeats it over an over
1helpful
2answers
I purchased the Patton PUH9000 heater last year. I puts out a lot of heat at first, but shuts itself off after about 5 minutes, then cycles back on after a couple of minutes. Is this normal operation? I...
My Patton PUH682 utility heater from 2011 is otherwise in excellent condition but Auto Safety Shut-Off seems to be a design problem. My overheat sensor quickly shut off the unit when surrounding air was cool. It is inside the bottom of the fan box wired between the on/off potentiometer and heating coils.
I identified it by turning on the heater and watched the metal contacts separate as it tripped. On my unit, the defective overheat sensor is hardwired. Since it was otherwise useless as a heater, I decided to jerry-rig it and hope for the best. I pried back the sheet metal edge of the fan box and wrapped the sensor with electrical tape. Then I took a very small squeezable metal paper clip and lined it with electrical tape. I clamped it over the overheat sensor and it fits perfectly to prevent the metal plates from separating. Now the heater works the way it should. The cable, coils and plug don't overheat on Hot setting and it runs continuously.
2helpful
I received the Patton Electric Heater model number PUH682 for a Christmas gift. It worked fine for about one week then just about 3 days ago, when I went to unplug it, the plug and cord were just red...
I saw your post and I encourage you to report your problem to The U.S. Consumer Product Safety Commission. I called them to report the problem. The number to the company (Patton) is 763 444 8567. The number to The U.S. Consumer Product Safety Commission is 1-800-638-2772. The U.S. Consumer Product Safety Commission will take your report and if you know others that have this product and they have experienced the same thing encourage them to call and report it. The heater I had melted unto a ultility extention cord and was smoldering. It could have cause serious injury or damages to me and my family.
If this product could have injured you as well. The are a public hazard and need to be recalled.
2answers
I have a patton puh682 1500 watt heater and after a while it just seems to turn off is there some kind of timer or heat control?
Under the main black knob is a bi-metal switch which shuts down the heat at various temps depending on your setting. Their is no timer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2answers
Defective Patton PUH680
How did you pay for the heater? Cash, credit card, or check? What store did you buy it from?
If you paid by credit card, some stores can look the purchase up. Some stores will accept returns for an equal exchange based on lookup of the charge.
If by check, you can get a copy of the canceled check from your bank. Take the copy with the heater to the store that you bought it, and they will likely allow an exchange.
If you paid by cash, you can contact the manufacturer, and he will ask you for the date code or serial number of the unit (he will tell you where to look). You can then discuss with them how to proceed to have the unit repaired or replaced.
15helpful
3answers
Top Patton Heating & Cooling Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Paul Carew
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
