SOURCE: Diswasher stopped working
there is a fuse in the washer that needs to be replaced reply to me and will walk you through it
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
about the only thing to try would be to remove the inner door panel to get to the control bd then you will see a mylar ribbon looks like a fat piece of scotch tape pull up on the plastic connector that holds it in and pull the ribbon out then get a clean pencil eraser and gently clean the ribbon and put it back in dont forget to push the locking tab back down then try it again and let me know
SOURCE: Won't start!
toggle between 'heated dry' and " normal ' until all light illuminate Then press cancel. now ensure door closes properly without striking cabinets slightly. The neutral for most components run through the door switch and jarring actiong causes a fault to be stored in computer. the toggle dance clears the fault code otherwise it will "fault code "again in three operations. hope this helps.
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
? Close the door.
? Push CONTROL/ON (if present on this model).
? Select the DRAIN/SPIN cycle.
? Select NO SPIN by pressing the SPIN SPEED touch-pad.
? Push PREWASH OPTION four times within five seconds. (If
PREWASH OPTION is not present on this model, press EXTRA
RINSE four times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
present on this model, press EXTRA RINSE two times.
Read more: Whirlpool
Duet Washer 'Control Locked' - The Laundry Appliance Repair Forum -
Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai
Appliance Repair Forums http://applianceguru.com/forum2/1540.html#ixzz1AbBWB73c
Get appliance parts at http://parts.fixitnow.com
