Rick, Thanks for your response but I am still confused about what to do. What is the electronic control? Is it one of the circuit boards? Another person said that the fault is a temperature sensor failure; to repair first replace oven temperature sensor. If F5 remains, I have to replace the main relay board (which Thermador no longer produces or stocks). Is there a connection/relationship between the Electronic Control you mention and the Relay Board?
Also I failed to mention that the oven makes a "clicking" sound before the F5 fault code appears. And when BSH replaced the display unit last spring, the tech had trouble connecting it to the Oven Control Board. Wondering if it's possible he accidentally loosened a wire connection that could have led to a short circuit and eventually to our current problem.
Please clarify "electronic control" and how to fix. Thank you very much DanRick, Thanks for your response but I am still confused about what to do. What is the electronic control? Is it one of the circuit boards? Another person said that the fault is a temperature sensor failure; to repair first replace oven temperature sensor. If F5 remains, I have to replace the main relay board (which Thermador no longer produces or stocks). Is there a connection/relationship between the Electronic Control you mention and the Relay Board?
Rick, Thanks for your comments. Model # is SC302TS. Looks quite similar to photo. BSH replaced the display board because it was unreadable -- the LCDs dimmed to the point that we couldn't read the display. Found out that BSH issued a technical service bulletin on display, so got them to replace it for free. The F5 problem came without warning. Top oven just stopped working while bottom convection oven is fine. I turned off power to the oven at the breaker for 15 minutes per BSH recommendation, but this did nothing. The F5 code appears about 3-5 seconds after I try to run top oven (enter temp, press bake). Any help would be appreciated. DanRick, Thanks for your comments. Model # is SC302TS. Looks quite similar to photo. BSH replaced the display board because it was unreadable -- the LCDs dimmed to the point that we couldn't read the display. Found out that BSH issued a technical service bulletin on display, so got them to replace it for free. The F5 problem came without warning. Top oven just stopped working while bottom convection oven is fine. I turned off power to the oven at the breaker for 15 minutes per BSH recommendation, but this did nothing. The F5 code appears about 3-5 seconds after I try to run top oven (enter temp, press bake). Any help would be appreciated. Dan
Rick Thanks for all of your advice. Turns out that the parts BSH replaced last spring (to fix the failed LCD display unit) included both the display panel and the electronic/power relay control board. BSH is going to replace the entire assembly ( display, relay control board, wiring harnesses) under warranty at no charge to us. Perhaps this was a problem that didn't get diagnosed when they came out for the display board or maybe the components they installed were faulty. Don't know. But BSH will provide all new parts and labor for free.
Also, I've seen a lot of comments/complaints about fading or failed display boards in both Rhermador and Bosch wall ovens. This is a common problem and once the display begins to fade (LCD line segments go out), the display unit will fail. It's not a problem that starts to occur and suddenly stops, leaving you with a partially legible display. Key point is that BSH issued a TSB (technical service bulletin) on this exact issue in 2009, so they are aware of the issue. If you press them, they will replace the components for zero labor and will usually offer you a deal on the parts (they offered us 50% discount). The stated reason for parts not being free is that oven is xx years old and beyond one year warranty period. After the first repair, we sent a certified letter to BSH and asked them to refund us for the parts charge as well as for a prior display module repair, for which we paid out of pocket. They sent us a full refund. We argued that their TSB was an acknowledgment that they knew the unit was defective, they failed to alert purchasers of the problem (via letters to registered customers), and that we as customers should not be responsible for a defect that was clearly within the design/manufacturing process even if the warranty expired. (Car companies issue TSBs all the time and don't charge customers for repairs). In the end, BSH did the right thing. And now, given that their initial parts replacement repair failed, they will fix it again at no charge.Rick Thanks for all of your advice. Turns out that the parts BSH replaced last spring (to fix the failed LCD display unit) included both the display panel and the electronic/power relay control board. BSH is going to replace the entire assembly ( display, relay control board, wiring harnesses) under warranty at no charge to us. Perhaps this was a problem that didn't get diagnosed when they came out for the display board or maybe the components they installed were faulty. Don't know. But BSH will provide all new parts and labor for free.
I have seen tons of controls go along side the touch pad but this is not the main issue when it comes to a thermador in my opinion. The main issue is the cost of these units where customers pay 8-10 grand for a very nice looking piece of equipment in which after 5 years I have seen them discontinue parts on the units such as the 486 models and the oven tempreture control. Hopefully with there new managment this issue will no longer happen on there newer models like it has on there older ones. Great news on getting your unit repaired by them always better when the customer doesn't have to pay for a control issue. If you have any further questions message me back and please also remember when our chat has fully concluded to rate how this opinion has helped in your appliance situation. By doing this it allows me to continue helping others in similar situations in the future. Thank you again RickI have seen tons of controls go along side the touch pad but this is not the main issue when it comes to a thermador in my opinion. The main issue is the cost of these units where customers pay 8-10 grand for a very nice looking piece of equipment in which after 5 years I have seen them discontinue parts on the units such as the 486 models and the oven tempreture control. Hopefully with there new managment this issue will no longer happen on there newer models like it has on there older ones. Great news on getting your unit repaired by them always better when the customer doesn't have to pay for a control issue. If you have any further questions message me back and please also remember when our chat has fully concluded to rate how this opinion has helped in your appliance situation. By doing this it allows me to continue helping others in similar situations in the future. Thank you again
Rick
RICKEAD1 provided 4 thumbs-up help and guidance to us. Invaluable. His knowledge helped us figure out that our current problem was related to prior repair by BSH, and we ended up getting the company to replace the joint display-power relay assembly at no charge!! Big thanks to Rick for helping us to get this problem fixed. d_korn47RICKEAD1 provided 4 thumbs-up help and guidance to us. Invaluable. His knowledge helped us figure out that our current problem was related to prior repair by BSH, and we ended up getting the company to replace the joint display-power relay assembly at no charge!! Big thanks to Rick for helping us to get this problem fixed. d_korn47
You can't post conmments that contain an email address.
F5 = EOC electronic control failure replace electronic control is stated in the service manual. If you have any further questions message me them back. Thank you
Rick
Tempreture sensor would be F3 error code the control it mentions in the service manual is the main control board in the unit but that service manual is very generalized to thermador. If you can provide the exact model number to your unit fully ,or is the sc302t correct that is up the top? I can give you not only a specialized diagnosis but also schematics pointing out which parts you would need to replace. Also you wrote that thermador replaced the display 6 months ago correct I have not looked at a schematic of your unit as of unit but if your unit looks like the one at top on left side showing a double oven the main control is located in back of the display and if I remember correctly is also connected to the display as well. I will await your reply before further posting a solution. Thank you RickTempreture sensor would be F3 error code the control it mentions in the service manual is the main control board in the unit but that service manual is very generalized to thermador. If you can provide the exact model number to your unit fully ,or is the sc302t correct that is up the top? I can give you not only a specialized diagnosis but also schematics pointing out which parts you would need to replace. Also you wrote that thermador replaced the display 6 months ago correct I have not looked at a schematic of your unit as of unit but if your unit looks like the one at top on left side showing a double oven the main control is located in back of the display and if I remember correctly is also connected to the display as well. I will await your reply before further posting a solution. Thank you
Rick
It is also possible the tech did not diagnose the problem correctly and once he found an issue with the display did not proceed with further testing of the control board as well. Question why did they replace the display? The display is able to work due to the main electronic control. I await your replyIt is also possible the tech did not diagnose the problem correctly and once he found an issue with the display did not proceed with further testing of the control board as well. Question why did they replace the display? The display is able to work due to the main electronic control. I await your reply
Dan only way usually to fix electronic control is to search for places that rebuild them or order them new in which getting em new cost to much Message me back your full model number and I will locate your schematic for you.Thanks RickDan only way usually to fix electronic control is to search for places that rebuild them or order them new in which getting em new cost to much Message me back your full model number and I will locate your schematic for you.Thanks
Rick
Question edited for typos. However "turn back"??
Frigidaire Error Codes
Error Code: F0, F1, F5, F6
Code Description: Electronic oven control failure
Solution: These codes indicate a malfunction in the electronic oven control. The electronic oven control (EOC) may also be referred to as circuit board, control board, mother board, ERC, or clock. Unplug the appliance for about 10 minutes to see if the error code will reset itself. When you reconnect the power, if the error code is still displayed, you can test the temperature sensor with an Ohm meter to determine if it has the proper level of resistance. If the oven control is failing or defective, replace it.
WHIRLPOOL Range/Stove Oven Fault Codes, Common
Failure CodeConditionCheck/Repair
Digit Failure Code2
F1
Analog to Digital Failure
Disconnect for 30 seconds - if display reappears - replace control board
F1
Safety flip flop
Replace board
F1
Shorted keypad
Replace keypad
F3
Oven temperature sensor opened
Replace oven temperature sensor
F2
Oven temperature sensor shorted
F3
Oven too hot
F3
Clean temp too hot
F5
Check door/latch switch
Replace switch if defective
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure Disconnect for one minute - if error comes back, replace control board F1 - Shorted control keypad Replace keypad F3 - Oven temperature sensor open Replace oven temperature probe F2 - Oven temperature sensor shorted Replace oven temperature probe F3 - Oven too hot Replace oven temperature probe F3 - Clean temperature too hot Replace oven probe F5 - Door latch switch fault Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop) Replace control board F2 - E0 - Shorted control keypad Replace keypad F3 - E0 - Oven temperature probe open Replace temperature probe F3 - E1 - Oven temperature probe shorted Replace temperature probe F3 - E2 - Oven temp too high Replace temperature probe F3 - E3 - Clean temp too hot Replace temp. probe F5 - E0 - Check door latch F5 - E1 - Check door latch Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error Replace ERC F1 E1 - EEPROM checksum error Replace ERC F1 E2:7 - UL A/D errors Replace ERC F1 E4:2 - Model ID error Reinsert keytail. F1 E6:0 - Latch signal mismatch error Replace ERC F2 E0:4 - Shorted key error Replace keypad assembly F2 E1:3 Keytail unplugged reinsert the keytail F3 E0:5 Top oven sensor open Test and replace top probe. F3 E1:6 Top oven shorted Test and replace temp probe F3 E2:9 Bake range over temperature Test and replace temp probe F3 E3:8 Clean range over temperature Test and replace temp probe. F3 E4:10 Bottom oven sensor open Test and replace temp probe F3 E:15 Bottom oven sensor shorted Test and replace temp probe F5 E0:14 Door switch errot Test and eventually replace door lock switch F5 E1:16 Door latch not operating Test and eventually replace door latch F8 E0:17 Refrigeration error Test the cooling module. PF Power failure - Does not indicate a fault. PF occurs when power is disconnected.
WHIRLPOOL Models SF3, 30'' and 24"
F2 - Oven temperature above specifications Check 8-pin connector from temp. probe to Electronic Oven Control F3 - Open oven temperature probe failure Check wiring, replace oven probe if necessary F4 - Shorted oven temperature sensor failure Check wiring harness, replace oven temperature probe if necessary F5 - Push button stuck or faulty Check for binding of pushbuttons and control panel glass. If OK, replace touch panel F6 - Electronic control logic error (timing) Replace Electronic Range Control (ERC) F7 - Electronic control logic error (lock motor) Replace ERC. F8 - Electronic control logic error Replace ERC.
that's a bad door latch,if you use the self clean don't use it anymore,the oven gets up to 1000 degrees and damages the electronics in the oven,takes out the clock assy. the door latch things like that.part number WPW10195934 go here to see parts go here put model number in and look up parts,also you can check all the error codes down in bottom right hand side https://www.searspartsdirect.com/model-number/RBD305PDB14/1198/0125300.html?searchType=modelSearch&q=Rbd305pdb14&searchTerm=Rbd305pdb14
go to upper oven and look at part number 22,you should have googled the error code before you changed out all those parts.
Hello, welcome to FixYa. Based on your post I understand you have an error "FC" on your Thermador SC272 wall oven, correct ?
There are two common scenarios with these Thermador wall ovens fitting what you've described. Either the lower oven control board has failed or there is a communication error between the control board and the display. Here is an exert from my Thermador service documents explaining in their terms...(hopefully it won't get partially cut-off when I click "submit" as it sometimes does with attachments, that's out of my control unfortunately). In either scenario I'd suggest calling in an authorized B/S/H/ (Thermador/Bosch/Gaggenau) service technician since it is pretty involved to trace and possibly replace (hopefully not) any failed/faulty component on these units. Hope this helps move you forward. Let me know if I can assist you further and good luck.
Hello, The F5 ERROR code means that the self check that the control (also called clock)board runs to check itself has failed and the control has detected a problem within itself and the control must be repalced.
Sorry you haven't had an answer to your inquiry yet. You may not even require a remedy any longer, but in the event you do I'll post it.
The "F5" in the smw272 wall unit is indicating the on-board watchdog has detected a oven temperature sensor fault/failure. The remedy issued by Thermador's tech support and authorized technicians service manual's is to first replace the oven temperature sensor. If the display should still display after wards, replace the main relay board.
It may be too late to suggest, but you may be best served having an authorized thermador tech look at it.
Hope that helps, better late than never hopefully.
For some reason I get the same error code every time we have a power outage. If you push and hold the "lower off" button for about ten or 15 seconds it will unlock and reset. Hope this helps.
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode 1. Intermittent oven temperature sensor or wire harness or, 2. Intermittent contact on power relay board" This doesn't help since it is too technical. What should I do next?
Rick,
Dan
Rick,
Dan
Rick
Rick
d_korn47
