20 Most Recent Whirlpool RBS305PDS Electric Single Oven Questions & Answers
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^^^^^
Whirlpool... | Answered on Aug 07, 2019
You can get all the codes here.
F3 E2 9 Bake range over temperature At room temperature, sensor resistance should be 1K to 1.1K. If not, replace the sensor. If the sensor checks okay, replace the control.
http://www.repairclinic.com/0078.asp#Westinghouse
Good Luck and Please Rate FixYa!
Whirlpool... | Answered on Jun 19, 2019
I bought a new oven found this one way to complex anyway. Afterall i just want to cook in it.
Regards
Ken Mc
Whirlpool... | Answered on Sep 10, 2018
Remove the glass bulb cover in the back of the oven by screwing it out counter-clockwise.
Click here for the manual.
Whirlpool... | Answered on Dec 28, 2017
500 degrees farenheit is 260 degrees celcius (metric)
any chance the display is set for metric ?
Whirlpool... | Answered on May 05, 2017
Hold down the 'ok' button and it should be fairly self-explanatory from there.
Whirlpool... | Answered on Dec 30, 2016
Hello Andy;
My name is Peter. I am a retired field service appliance technician.
I am sorry for the above response. Some advisors on this site are not knowledgeable in the field and answer questions regardless of professionalism and rudeness just to build up points on this site.
Anyway, I am here to help you.
First you have no thermal fuse and you power is 220 and 240V.
There are only three components that control your oven:
1.0 The heating element - Inspect the heating element (Metal bar) inside your oven. Is there a crack in the element. Inspect the two connectors of the heating element against the back wall for corrosion. When you turn the oven on do you see sparking? Then you have a bad heating element.
2.) Ok, the heating element is good.
3.0) Turn on your broiler. Does it glow bright red? Then your thermocouple is good.
4.) Then your problem is in your oven control board. Sears will cost about $256.00.
I just purchase a remanufactured oven control board over the internet for my customer for $30.00. Easy repair.
Send me your model number. Either on the top of your oven door or on the face of your oven after you open the door.
Whirlpool... | Answered on Feb 06, 2016
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!#@EWSF
Whirlpool... | Answered on Oct 13, 2015
this is one of common issue with oven when control board starts malfunctioning. Try replacing your Oven Control board. if you know the Control board part number then I would recommend you to purchase one of them from Partsimple.com. Since Partsimple is more reliable, convenient, affordable for control boards. You can either purchase a new one or even a refurbished one which work same as new one..
Try once... and let me know if required any further help on this. TV parts Water Filter Washer parts Laptop Parts Replacement Parts...
Whirlpool... | Answered on Sep 03, 2015
@Michaeal: here is the video which will help you to fix the door back to oven.
Hope this video help.. Happy Fixing.
Whirlpool... | Answered on Jul 15, 2015
When you re-install the door, make sure it snaps in tightly; inspect the clutch connection.
Whirlpool... | Answered on Jul 14, 2015
Your cancel key is defective at this point. follow these steps below?
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Whirlpool... | Answered on Apr 24, 2015
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.
You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Whirlpool... | Answered on Apr 09, 2015
yes the interlocking mechinism sends a message to the control board?
If you have a problem with your cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Whirlpool... | Answered on Apr 02, 2015
Timer
To Turn Tones Off/On: Press and hold TIMER SET until a tone
sounds. The display will show "TIMER" and "NA9 On" or
"TIMER" and "NA9 OFF." To remove from the display, press
UPPER OFF, LOWER OFF or OFF/CANCEL. Repeat to turn
back on.
Whirlpool... | Answered on Feb 26, 2015
shanco, is your clock working at all, does it display. If not, you have a thermal cut out on the back of that oven. This runs through the neutral side of that clock. If that TCO is open, the clock and display will not function. Part number 4451442. Very inexpensive. You can look it up at repairclinic.com for a price. They will have a picture of it. Now I'm going by model number gy396lxb00. You have to remove the back panelto get at it. According to the schematic Im looking at it looks to have 2 red wires going to it. Catriver
Whirlpool... | Answered on Jan 11, 2015
Whirlpool RBS305PDS Electric Single Oven Logo
176 questions posted
Top Whirlpool Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Ovens
  • Whirlpool Ovens
Most Popular Question
bypass thermal fuse block see oven will
  • Ovens
