20 Most Recent Thermador C301U Electric Single Oven Questions & Answers
Thermador oven (c301u) door hinges weak, how to install new hinge
This is a relatively easy fix however you will need to remove the door and it is heavy!
Start by opening the door completely and engage the small "locks" that are at the base of the hinge. This will ensure that the spring loaded hinges do not "spring open" when you remove the door. You then will need to remove the hinges from the door via a series of phillips head screws that hold the hinge assembly in place. The new hinges must be "preloaded" into the Open position using a vise or some means of holding the hinge in place while you use a small section of pipe to provide leverage needed to open the hinge so that the Locks can be engaged.
Once the new hinges are "pre-loaded" and the locks are engaged, you can reverse the procedure to re-install the hinges into the door and re-install the door.
Good luck!!
The hinges are commercially avaialble from Applianceparts.com
7/9/2018 2:22:41 AM • Thermador C301U... • Answered on Jul 09, 2018
Self cleaned sc301 electric oven now when you
Welcome to FixYa.
You have not mentioned if the oven has displayed any error code so I will take that for what it is...there was none shown.
With that, I`d start by looking for an over-temp cut-out tripped. Since this problem started following a self clean cycle, it leads me to believe it is just that.
Here`s what and where to look for for this,
Fortunately if it is tripped, they are the manual reset type and are accessible behind the black grill/vent just above the door and just below the control panel next to the lock latch assembly.
**Turn off the 40amp breaker at your service panel or sub-panel in the home before attempting any service...safety first**
With the power off, you should be able to remove the grill and push the red button in the center of the thermostat and that should fix your problem...as shown here,
macmarkus_108.jpg If indeed the hi-limit is tripped you`ll know immediately because you`ll feel it click as you push it down. It will look like the image below...
Ultimately it could be a faulty relay board or related to the timer, but I`d start with the hi-limit cut-out tripped first.
If the images I attached are not clear or you just want more info, I can send you a complete service manual in a "pdf" attachment, however you`d need to provide an email address to where I could send it to you.
Other than that if you call in a pro just be sure they are an authorized B/S/H/ service provider ( B/S/H/ is the parent company for Bosch, Thermador, Gaggenau, Siemens products ).
Let me know and I`ll watch for your reply and respond as soon as I can. Good luck.
Regards,
Macmarkus :)
9/23/2015 1:25:47 PM • Thermador C301U... • Answered on Sep 23, 2015
Thermador CM302 f63 error code
overheat situation. check oven sensor and soldered pin points for sensor wires at relay board. Resolder if needed.
2/5/2015 11:59:45 PM • Thermador C301U... • Answered on Feb 05, 2015
Cooling motor on Thermador C301 oven should stay
could be a relay board problem. may be a bad solder connection on it. Inspect all with a good magnifier. resolder as needed.
2/5/2015 11:48:02 PM • Thermador C301U... • Answered on Feb 05, 2015
What is error code f13?
The F13 fault code on this type of range indicates that the EEPROM (Electrically Erasable Programmable Read-Only Memory) on the control board is bad. This can be caused by a power surge or glitch through the electrical lines. You can try to reset the control board by completely unplugging the range (or shutting off the breaker) for 5 minutes. If the error code returns after plugging the range back in, then the control board for the range will need to be replaced.
2/5/2015 2:42:56 PM • Thermador C301U... • Answered on Feb 05, 2015
I have a thermador oven x302xp getting code f33 on displ;ay
oven over temperature. replace oven sensor, replace relay board if repeats.
2/3/2015 2:21:45 AM • Thermador C301U... • Answered on Feb 03, 2015
Code F34 Thermador Model # C302W
fan/air flow issue.
2/3/2015 2:08:03 AM • Thermador C301U... • Answered on Feb 03, 2015
Our Thermador oven starts to beep when you shut it off and the way we are getting it to stop beeping is to set up a fan in front of the open oven to get it to cool. This stops the beeping after 10 m
Check if the internal ventilation fan is running. It is intended to cool down the oven exterior. Some units made 2004-2007 can overheat during self-cleaning.
11/27/2014 7:46:15 PM • Thermador C301U... • Answered on Nov 27, 2014
How do I turn off f13 beeping
For most codes, Touch OFF or turn power off at the circuit breaker, wait 3 minutes and turn it back on.
11/27/2014 7:41:01 PM • Thermador C301U... • Answered on Nov 27, 2014
F33 CODE
this is uper oven over temperature while cooking , check sensor should read 1080 ohms, at room temp, if ok replace power relay board
12/2/2011 2:01:23 AM • Thermador C301U... • Answered on Dec 02, 2011
Thermador 30" wall oven.
Your touch in put key is stuck, replace ,power relay board and the touch panel Always unplug the oven first before service
12/2/2011 1:59:03 AM • Thermador C301U... • Answered on Dec 02, 2011
I have a Thermador C301-UW
F34 ( Upper oven cooling fan air switch not detected ) Replace air switch,cooling ...on door
12/2/2011 1:53:56 AM • Thermador C301U... • Answered on Dec 02, 2011
Thermador C301U Electric Single Oven Logo
72 questions posted
Top Thermador Ovens Experts
ZJ Limited
ZJ Limited
vince
john h
Are you a Thermador Oven Expert? Answer questions, earn points and help others
View Most Popular
Thermador Ovens
  • Thermador Ovens
Most Popular Question
thermador oven c301u door hinges weak
  • Ovens
