When i print out on paper , the printer copies and prints but the printed copy is powdery and wipes of page . i dont know what i can do . i have changed tonner drum and also some of the cartriges.
I agree the fault is almost cetainly with the fuser unit.
How do i fix this problem
Http://www.precisionroller.com/fuser-assemblies---units-for-samsung-clx3170fn/details_58624.html
sounds like fuser failure
In laser printers, the drum helps to place toner powder on the paper according to the required printout.
Then the fuser unit heats the toner powder to permanently 'paste' it to the paper.
Seems like your fuser unit has malfunctioned.
Toner rubbing off the page after printing indicates a fuser unit problem. The fuser unit uses heat and pressure to "fuse" the toner onto the paper as it passes thru. It sounds like you wither have paper wrapped around the rollers or a bad fuser unit. I would do research on the availability of a fuser unit in your area or someone local who can check the fuser unit for you.
Thank You for using Fixya
