20 Most Recent Samsung CLX-3170FN All-In-One Laser Printer Questions & Answers
Forget SmarThru. Download Samsung Universal Printer Driver 3. It must be version 3. Install that, make it your default printer and delete any other supposed Samsung printer drivers. When you go to Scan, the program should automatically download Samsung's Document Creator and this will work your fax simply and easily. Anyway, it works for me.
Samsung... | Answered on Dec 19, 2018
Hello!
Here is the "MAINTAINING THE CARTRIDGE" for your device.
Please check it, and "Troubleshooting" part as well. Hope it will help!
https://manualsbrain.com/en/manuals/113019/?page=65
Samsung... | Answered on Sep 15, 2017
Could be the Software/firmware does not know the other commands that you printing software on computer are sending to it. Check the firmware on print server for any updates.
Samsung... | Answered on Sep 01, 2017
Paper has jammed In the fuser area (open back door to fuser area) or Check Inside around the toner cartridge
Samsung... | Answered on Jun 10, 2014
hi, please clean the printer lsu(laser scaner unit).its located under the printer ,you taken the papper tray & look the lsu is fixing the 3 screew please remoove the screew & connecter cable & then clean the lasu mirror & moter
Samsung... | Answered on May 06, 2014
check drum
Samsung... | Answered on Mar 31, 2014
http://mkmservice.ucoz.ru/load firmware for Samsung ML-1660/1665 and other
Samsung... | Answered on Mar 21, 2014
I agree the fault is almost cetainly with the fuser unit.
Samsung... | Answered on Mar 18, 2014
There are two possible things that can make such a problem:
1.The drum of the toner cartridge had and his life.If you take out the cartridge,turn it around and you will see a big metal roller.The color of the drum should be all the sime all over the drum.If there are brown line around the drum thats mean it it time to change the drum of the cartridge.
2.The PCR(Primary charging roller) could be damage.The PCR is located in the toner catridge and youu need to take apart the cartridge to see the PCR.To do that you may need a proffesional help.
Samsung... | Answered on Jun 09, 2013
The drum fills up with waste toner and you can empty it but its messy and you need to clean everything carefully after taking it apart. Take out the imaging unit, unloosen the screws on both sides, unmount the retainer springs and push the center pin out of the drum. Take out the drum and unscrew the two screws that were hidden behind the drum. Now take away all parts so that you can empty the waste drum container. Clean everything especially the light emitting panel, drum and white plastic cover needs to be clean. Hope this helps.
Samsung... | Answered on Feb 21, 2013
Samsung CLX-3170FN All-In-One Laser Printer Logo
Popular Tags
113 questions posted
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Office Equipment & Supplies
Most Popular Question
printer prints out but all powdery wipes
  • Office Equipment & Supplies
