20 Most Recent
Samsung Clp415nw Color Laser Printer Questions & Answers
Error #a1-4111 on a sasung printer/copier model CLX-4195Fw
Hi, it's Actuator Motor Error, check and ensure that all orange plastic cover has removed from the toners. If cover has been removed, probably you need to check the solenoid on the top after you have remove the right side cover. If still persist, you need to replace the main board.
#a1-4111?
Hi, it's the Actuator Motor Error. You need to removed the right cover and locate a solenoid on the top, and check if it's working fine. Otherwise need to replace the main board.
A1-4111
I used samsung clp-415nw in China,the input power I have change to 110v ,but it has error #a1-4111 call for sevice.How i can do buy myself. tks!
I have a samsung C410W printer which keeps on flashing red and will not print. Help
Samsung printer C410W. Red light flashing.Checked paper paths; checked cartridges (nothing lower than 85%); removed and returned cartridges; checked back panel paper path. Still flashing red.
Technician's Assistant: Have you tried running your printer's self-cleaning cycle? (Sometimes you have to run this several times to see results.)
Is the self-cleaning prompt in the Easy Printer Manager?
Technician's Assistant: Have you tried wiping down the metal contacts on your printer and cartridges?
I have now wiped them
Technician's Assistant: Anything else you want the Printer Expert to know before I connect you?
How do I start the self-cleaning cycle?
I can't show ip address of printer samsung ml3312nd
In Windows, you can use the Control Panel to find the printer's IP address.
- Go to Settings > Devices > Printers and Scanners.
- Find your printer in the list, click on it, and select Manage.
- Click on Printer Properties.
- In the General tab, find the Location field. Your printer's IP address will be located in it.
For MAC OS click the Apple sign and locate printers.
