HP Compaq Presario SR2013WM (RE468AA#ABA) PC Desktop Logo
Anonymous Posted on Oct 16, 2011
MY Compaq Presario SR1931IL Desktop PC NIC drive is not showing so not able to connect to internet
James Miller
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • HP Master 2,226 Answers
  • Posted on Oct 17, 2011
James Miller
HP Master
Level 3:
Renaissance:
Answers
2226
Questions
0
Helped
447573
Points
2985
In cmos you have to enable it to work do you know how to do it jim?
Ethernet port ligght off
go into your network properties.
Right click Network/Properties then right click on the network and choose enable if it has been disabled.
I have a compaq presario SR1303 Wm Desktop I wont connect to internet, stating that local area cable is unplugged, however this isn't true because I have another desktop same model that works fine...
If all looks good try right clicking on network status icon in sys tray and use repair. A more advance option would be to use ipconfig from the command prompt.
Start > Run (search in Win 7) > type ipconfig /release. Then ipconfig /renew. ipconfig ? will show you all the options. Good luck.
Integrated ethernet card on Compaq Model SR1650NX apparently failed. What is best inexpensive PCI Ethernet Card to use, if any?
you can buy just about any PCI NIC card from ebay or even walmart and they should work. make sure they are compatible with your OS. it will say on the box.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
I have an HP PResario SR1220NX desktop that needs a new NIC card and sound card. Do they make wireless NIC for this model?
As long as you have an empty PCI slot (white) you can buy any brand wireless card or even a USB wireless adapter
The onboad NIC card is not recognised by device manager when I reinstalled windows xp SP2. I've downloaded the correct NIC card drivers for a presario SR2020NX directly from their website. When I look...
Uninstall the drivers for the device completely and restart the system. It should install the correct drivers upon restart. If not, retry installing the NIC card drivers that you download.
Are you sure that you download the ethernet drivers and not the Utility program? It's easy to confuse the two.
I have a Compaq Presario 220 slimline desktop. I
I guess, it was Compaq Precario 2200 not 220 . You can click the link below to download the appropriate drivers.
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=12454&prodSeriesId=96354
Awaiting response.
2 NICs connecting to 2 different networks
you need to speak to your network administrator, for printers you get network enabled printers ( your network admin will assign an IP address and sharenames for your printers,
your network admin can create shared volumes on the network and can sort out internet routing that complies with the corporate domain.
sorry no easy way to do this
Connection to Internet problem
you need to know what brand and model is your network interface card (nic). you need to look for the driver for this nic in order to function properly.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
