without knowing age of unit, I suggest replacing the motor. Sounds like the armature is worn the bearings and is moving inside the windings of the motor. I would do that first before moving forward with any other repairs.
It seems that the timer has failed and needs a replacement. If this seems to turn around without clicking and if there is no action when the program cycle is initiated, this seems a failure of the timer controller unit. This happens in cases when it is turned around in reverse order or violently.
Some of the old washers have a delay between each cycle that seems long but less than 2 minutes. If this is not the cause you will need to order a new timer not the knob. Sorry if its very old it may not be worth it.
it's possible go to www.repairclinic.com and enter the numbers you have posted and it will show you what they are. I have the same problem. What I did was not pretty but it works for now. I broke a piece off of your part#387997 and simply turn my dial that way and then pull the center out to start the wash. Considering a new timer is close to $100+ and it works fine this way , well you know...
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
The timer is not stopping the agitate mode. And the timer is suppose to have its own off setting at the end of cycles. Suspect pretty strongly that the timer is at fault. Cant say for sure without looking at a wire diagram and eliminating any other controls.
If this helps you please rate me as high as possible. If it doesn't help you please rediscribe your problem in more detail to help me understand, post back and I will follow up.
yep you need a new timer part. on your search engine type in ge dishwasher model number then scroll down to find timer part number order it only if your can take broken one out if u cant then u need to call repairman.
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
