The problem you're experiencing can be caused by several things:
1. The humidity extraction level is set to HIGH. Lower it to 35%
2. The air intake filter is dirty or clogged. Remove and clean the filter, as necessary.
3. The float valve in the top of the water collection bucket is broken or stuck in the UP position.
Remove the bucket and inspect the float valve for damage and freedom of movement.
4. The water collection bucket is not installed properly. While the bucket is out for checking the
above,be sure to reinstall it "squarely" from top to bottom into the bucket holder. It needs to
make firm contact with the bucket safety removal switch on the rear wall of the bucket holder.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Hi lynn crisp, thanks for your post!
From my understanding you are having a challenging time with your Frigidaire dehumidifier shutting too quickly. It sounds like a possible problem with your sensor or control panel. Are you currently under warranty? I would contact your manufacturer for assistance to a proper resolution. -Matt
