Question about Fedders Dehumidifiers
The unit runs but does not produce water. - Fedders Dehumidifiers
    Brigadier General:
  • 4,736 Answers
Sandy, usually there are 5 basic causes for what you have described. They are all solvable. Pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, remove and clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to clean
the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees F. Dehumidifiers do not work
well between those temperatures (Unless, you have a Low Temp Unit). This applies mainly to
basement applications, where the air temperature at floor level is colder than at shoulder level.
Raising the unit up off the floor, onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks
Posted on Jun 21, 2011
SOURCE:
I have a brand new dehumidifier (properly sized) that is running 24 hours/day and producing some water (roughly 1L).
with a reading of 66 to 67 % rh this is a bit low for normal rooms humidity , I cant see why you'd want to try to get it down to 55% unless its for a special purpose (drying paint?) , I get this question a lot from folks , what I tell em is if you set your airconditioner in your home down to 30 degrees would your house ever get that cold = "no " the houses ability to heat itself is greater than the a/c units ability to cool it (even if its properly sized) so why would you expect a small appliance like a dehumidifier to be able to do any different ? all you end up doing is over working the appliance and costing you extra money in lost power
the general excepted room humidity is 70% rh this is a industry standard ,that all appliances are designed to achieve , and yes as the room gets dryer it will extract less and less water from air
Jul 29, 2015 | Dehumidifiers
Not producing humidity
If this is a unit that has been used for some period of time,it may be clogged and in need of cleaning
Dec 09, 2012 | Kaz inc v3500-n v3500n
LG unit has run great for 4 years and now does not produce any water. Seems to run fine, filter is clean, can hear compressor starting. Just does not dehumitify.????
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 06, 2011 | LG LHD45EL Dehumidifier
Unit appears to operate normally, but does not produce water
heatman101
Apr 18, 2011 | Whirlpool Dehumidifiers
It is not producing water, it runs but no water is collecting in pan.
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again.
Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue.
This situation will have to be addressed by a qualified technician.
Take care.
Aug 19, 2010 | Whirlpool AD25BBK Dehumidifier
Everything deems to be working but no water. Unit turns on as required and is running. can change fan speed but do not hear a differance and unit does not produce water.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Feb 13, 2010 | Kenmore 54501 Dehumidifier
Dehumidifier running but not producing water
Sounds like your relay switch isn't connecting....
Apr 29, 2009 | Maytag M7DH65B2A Dehumidifier
Not collecting water
If everything is running and no water is being produced the system may have lost its refrigerant. There are two motors in dehumidifiers. One is the fan and the other is the compressor. Make sure they are both running.
Jun 18, 2008 | Goldstar DH304 Dehumidifier
Dehumidifiers Logo
221 people viewed this question
Top Fedders Dehumidifiers Experts
Steve Allison
Steve Allison
Bill Long
jasbo
jasbo
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
