Ok ,,take your time and get a flash light,,check the rubber gasket around front of tub for pen hole...giood luck,,if you dont find leak repost..and we will got to another step..pull on rubber tub gasket while searching..
thank you,if direction are needed for changing gasket ,,repost please
It's the gasket I need to know what to change it please advise. There is a large area of gasket that is not attached to the washer that's were the water is coming from. Thank you
also adivse where to buy the gasket thank you
WELL I HAVE EVERYTHING YOU NEED ACCEPT PART IF YOU NEED A PART,,BUT I CANT POST PICTURES TO YOU .WOW I THINK THE INNER CLAMP WIRE SLIP OFF,,
WELL IWILL TRY ANY WAY ,,I HAVE PICTURES BUT I CAN ONLY POST THEM ON A FRESH QUESTION...GO TO THE FRONT OF UNIT,,OPEN DOOR NOW THAT GRAY GASKET THAT YOU SEE ,,ON THE OUTSIDE CLOSEST TO YOU TAKE A SCREW DRIVER AND PULL THE OUT SIDE SPRING CLAMP OFF USE YOUR HAND AND FELL FOR IT FIRST OK WHEN YOU FELL IT PUT SCREW DRIVER UNDER WIRE AND PULL OFF..NOW PUSH GASKET BACK .DO YOU SEE ANY GAPS WHERE WATER CAN GET OUT THERES ANOTHER BIGGER SPRING WIRE CLAMP ON THE FAR SIDE OR TUB SIDE IS IT THERE OR DID IT JUST SLIP OFF
It is so common that the drain leaks in many ways and
is the most problematic fault in a washing machine. In all occasions it is
important that your observation is most important and so is vital to the
identification /rectification and solution. If you have noticed that water has
leaked then as the drain hose pump/valve and fittings are located on the
underside of the machine it is important that you look for possible leaks here.
In some cases the drain hose would be clogged at the drain end to outlet of the
house and so there will be back flushing resulting in overflow to the outside.
Also the drain pump/valve can be clogged or the drain hose clamps can be loose
on the grip which can all cause the leak to occur. Removing and cleaning the
drain pump/valve, tightening of the hose is also very important. Also water can
leak if there are gaps on the front door gaskets and must be checked but this
will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Please adivse how to change a gasket. There is a large whole on left side the gasket is not attached to the washer thank you
yes. it's the gasket how do I change it and were do I buy the gasket
