Maytag Ensignia MAV2757AWW Top Load Washer Logo
Posted on Nov 14, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Maytag Ensignia model MAV2757 AWW. The washer basket doesn't balance, even with a small load, and turns off due to the weight being unbalanced. The springs are there and oiled, the hardware isn't broken. Everything structurally looks good. Is there anything else that would cause the basket to spin unbalanced?
Chris Huff
Level 3:
Top Expert:
  • Maytag Master 6,289 Answers
  • Posted on Nov 14, 2017
Chris Huff
Maytag Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2020487
Points
74913
Snubber ring that tub and spin basket assembly sits in is most likely worn. Very inexpensive part but extensive labor involved. I would suggest calling a competent service tech.
4 Related Answers
Anonymous
  • 3 Answers
  • Posted on May 29, 2008
SOURCE: Basket out of balance
Mine actually bent, and had to be replaced.
Anonymous
  • 100 Answers
  • Posted on Apr 11, 2009
SOURCE: Maytag top load washing machine model PAV 2300
If you have replaced the spring is the tub over to one side not in the center of the hole there is what they call a snumber ring on the bottom of the base the washer sets on that could be wore out but it is really hard to replace and you will need a special tool to compress the break
Anonymous
  • 121 Answers
  • Posted on Jun 11, 2009
SOURCE: Have a Maytag Ensignia top load, Washer basket is
sounds like your balancing ring or your springs gave out underneath to balance load
Anonymous
  • 699 Answers
  • Posted on Feb 05, 2011
SOURCE: I took my basket out because of an unbalancing
Normally excessive shaking etc is caused by 3 things.
1) Unbalanced load. 2) Brocken spring that suspend drum. 3) Dampers under drum lost damping.
I would expect 3 as likely cause if machine works ok except for when spinning.
Why does the Drum spin erratic even without clothes in it?
might be a warped spin basket or the dampers could need to be replaced. could even be a bad spin bearing. if it was bearing, normally would be associated with a loud noise during the spin cycle though.
Please settle a dispute with my husband. my washer has an off balance load. do I have to remove things, or will adjusting the load eventually work to even it out?
the off balance sensor won't adjust the load,, it will notify you if the load is so far out of balance that it needs to be re adjusted . I hope this reply doesn't effect the rating I will receive :)
1helpful
Badly out of balance in spin cycle. When the machine goes to the spin cycle it vibrates and begins to walk. The machine will not balance the load small or large.
The legs underneath the machine become stuck from rust and corrosion. I had the same problem and all the repairman did was hit the legs with a screwdriver and it unfroze the legs and fixed the problem!!
My Maytag neptune is extremly loud
A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive, or loud noise. There can be several causes and the problem is worse with some units more than others.The most common cause is an unbalanced wash load. Open the lid/door, and attempt to redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit. A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See your manual on how to level your washing machine.The outer tub/basket, is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons/shock absorbers, may begin to wear out and not support as much weigh as needed.
Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be the best action.Another common cause for excessive movement, or clunking, is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
NOTE_ Verify That the shipping system including shipping bolts, spacers and cables are removed. This is a common issue when a new washer is installed.
Maytag top-loader making very load creaking noises from agitators
it could be you lelft something in the pocket of your pant that fell out an didnt drain out an si in the bottom of washer tub you have to remove the agitator an the basket if you dont know how call a techican ok are try an take a flashlight an see if you see any thing stuck in the bottom are the side of the basket ok
2answers
My Maytag Ensignia washer is not spinning well. It bangs side to side with even the smallest loads. It seems like something is loose. Is this something I can fix myself or do I need a repair mans help....
Try leveling the washer... If the washer is level, then don't wrap the clothes around the agitator...drop the clothes straight in, on top of each other evenly around the agitator. The Ensignia washer has a Dual action agitator... That means the clothes roll over them selves, instead of moving side to side, as with a traditional agitator. wrapping the clothes around the agitator will cause the load to be un balanced and then cause the "banging" noise... this should take care of the problem...
2answers
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
