You may be asking too much of the unit; the 5800 watts a which it is spec'd, may be a 'peak' power rating which may be 15-20% higher than its continuous rating.
30 Amps at 220 volts implies 6600 watts which is higher than even the peak power rating.
I would expect the unit to produce ~4800 watts continuous or around 22 Amps.
Decided to check my statements and found this, which I quote:
Generator Volts AC (60Hz) 120/240 Max. Output Current 5800W-48.3A/24.2A
Rated Output Current 4800W-40A/20A Volts
DC (AMPS) 12 (8.3)
Maybe I didn't explain this right. The generator isn't powering anything. It's just running at high idle and I checked the receptacles with a multi meter. It has 3- 220 receptacles and 1-110. If that generator is not powering anything it should have the correct output to each receptical.
Sorry, had to grin- yes, it wasn't clear what your problem was. I agree, at no load, you should have at least the rated voltage and most will measure somewhat high. I would first try a moderate load since it may be exxceeding an overvoltage limit briefly while running up that is causing it to disconnect. Try it with a moderate load of several hundred watts if you haven't done that yet. If it still misbehaves, it's time to start doing continuity checks and there may be a concealed fuse that has blown. Most units will have a resettable circuit breaker and then a fuse rated well above the generator's limit to prevent destruction in case the circuit breaker fails to trip as it should. Since this is a brushless type, it is using either a static or rotating field magnet. One I had years ago had extremely close spacing between the rotating magnet-equipped disc and the stationary field coils. The final death was due to the disc's bearings failing which electrically shorted the field coils and blew a fuse well above operating limits.
I replaced the bearings and carefully ground away the shorted areas of the field coil which restored operation but with a reduced output current capability.
