20 Most Recent
Makita 2,800 Watt 6 Hp Portable Power Generator #G2800L Questions & Answers
Makita Generator G2800R
Check your tank for contaminants (water, trash, dirt, monsters, etc), as well as the balance of the fuel system. You may also need to remove the carburetor and clean it out, particularly if the generator has sat for more than a month with fuel in it (most do, including mine) and now has deposits. The only thing that the choke does is make the mixture rich by cutting off the air.
And just for grins, look at the spark arrestor screen on the muffler. This can be related and problematic as well.
My g5501r stopped generating,engine runs
There is at least one and possible two fuses and one most
likely has failed. You need to remove the blow fuse and replace it. Mine were the size of two D sized batteries
put together. I have a generak 10k and I
experience same problem. I purchased two new fuses and all is well.
What is the common cause of not starting of makita generator g5500r
My guess and the most common complaint on fixya -
the gas was left in the engine from the last use and turned to gunk.
Drain the old gas. Clean the carb.
If it will run for a little after removing the air filter and putting a couple of quick squirts of starter fluid into the carb, it means the carb is gunked up and all the orifices need unstopping.
9/20/2017 3:13:17 AM •
Makita...
Answered
on Sep 20, 2017
What does a diode stack assmelly do on my
makita g5501r parts Power Generators Questions & Answers
www.fixya.com > Forum > Tags > makita g5501r parts
Power Generators makita g5501r parts questions and answers. ... I own a makita 6100generator and it is only putting out about 105 volts ac and about 208 volts .
11/18/2015 1:20:42 AM •
Makita...
Answered
on Nov 18, 2015
